What type of glue is best to repair headlight bezel
Glenn S
RTVX900, NH Boomer 50, Cub Cadet TRS, JD 350C, IH 584 and attachments
Oct 20, 2018
Alberta
I broke the leadlight plastic bracket, any recommendations as to the best type of glue for this? Ideas for repair? Don't hold the tractor color against me. :)
5,722
Check the piece for a triangle and a number in it or some letters...
'PC' is PolyCarbonite, 'PE ' is PolyEthylene,..PVC PolyVinylChloride....
The 'trick' is to buy the CORRECT adhesive.
Be sure to 'ruffup' the join area and allow the 'glue' to CURE....usually 24 hours...
Rcflyer330
Kubota B2650 Cab, B2779 Broom, B2782B Snowblower, RB1672 rear blade
Oct 14, 2019
112
62
Traverse City, Michigan
Just a guess from pictures I could find online from other headlights it looks to be PP >GF20< translated this is polypropylene plastic that is reinforced 20% with glass fibers. If you going to glue it jb weld would work but plastic welding would be better.
Take a look at the polyvance videos on YouTube. The only special equipment you need is a soldering iron or wood burning tool and some of the same plastic. Or if you have a harbor freight nearby they have a plastic weld kit and some plastic rods for fairly cheep.
