Has anybody tried running X-blades on a BX2380 w/ a 60” deck? I see a lot of articles with people using this set up but they are all using commercial mowers (zero turn / stand up).
just curious.
just curious.
Never heard of X-blades and had to Google it. These are 2 blades on one spindle in an X pattern. I have never heard of the practice before so I have no idea how good they are.Has anybody tried running X-blades on a BX2380 w/ a 60” deck? I see a lot of articles with people using this set up but they are all using commercial mowers (zero turn / stand up).
just curious.
I have never heard of them either,Has anybody tried running X-blades on a BX2380 w/ a 60” deck? I see a lot of articles with people using this set up but they are all using commercial mowers (zero turn / stand up).
just curious.
I agree with what you say, but man....sometimes I just want to believe there is something out there that is better then we've seen so far!Honda commercial mowers come with X-type blades standard (for mulching).
Generally the OEM picks the best blades for the job, mower deck design, and price point; pretty much everything else is a fad that fades in 3 years.
X-blades work, but the material flow under the deck has to handle the blades and stacking height, otherwise clumping or some sort of poor cut can occur.
I suspect OEMs select the best blades for the widest variety of mowing conditions, safety, blade lifespan, etc. and that for certain mowing applications some aftermarket blades do better than OEM, and conceptually that makes sense that some blades do some things better than others, even if it's a narrower range of application (like toothed blades for mulching). (But my relatable experience is in the car/motorcycle/truck world, so am only taking a guess tractor engineers follow the same general guidelines.)I agree with what you say, but man....sometimes I just want to believe there is something out there that is better then we've seen so far!
How about the Meg-Mo blades? They put a hub on each spindle with four short rotating knives. They are set up just like the blades on a disc mower, they rotate on a hub. Most all the reviews I see just say they don't do a good clean job of cutting one's lawn, and they are expensive.
On a disc mower the grass may be two/three feet tall and it's cut off 2" above the ground and is laid flat and the mower moves forward., come back next day, rake and bale so it's two different outcomes desired.
He makes the BEST mower blades. Truly revolutionary. Grass just cuts itself.Never heard of X-blades and had to Google it. These are 2 blades on one spindle in an X pattern. I have never heard of the practice before so I have no idea how good they are.
Interesting. Did you make a jig to get the same life on each blade end? Did you experiment with the angle?Years ago I fabricobbled a couple X blades. Wasn't impressed, but I may not have engineered it properly.
The 7-1/2' rear discharge RFM on the L4240 has 5 Gator blades and they work very well. This is the mowing machine of choice.
The 5' side discharge RFM on the Ford has regular blades to which I added small wings to increase air flow (pic below). The main purpose was to make it better at blowing the leaves off the yard in the Fall. It works well for that and the occasional normal mowing.
I cut the add-on pieces as uniformly as I could. Then clamped them to the existing blades for welding at the same angle as the factory upturned part of the blades. Following welding, I balanced them by griding material from the heavy ends. They work well enough that I scrapped my homebrew 3-point leaf blower.Interesting. Did you make a jig to get the same life on each blade end? Did you experiment with the angle?
Apparently there's a not-yet-available Artificial Intelligence robotic mower with dual-layer blades (that's new) for better munching (mulching),He makes the BEST mower blades. Truly revolutionary. Grass just cuts itself.
