Pallet fork grapple
Showmedata
LX3310
May 18, 2022
210
200
Boulder CO
With the snow finally finished (fingers crossed), I got to put on my winter fab project: the one-armed pallet fork grapple.
I saw one for sale by a Canadian vendor, but it was pricey and I like makin' stuff.
Actuating it here with the tractor at idle, obv. it moves a lot faster when the revs are up:
<iframe width="583" height="1036" src="
" title="" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
The primary intent is for handling logs, but it's also handy for stabilizing loads:
Also really gives you something to bang your head on when it's raised up above the skid full of logs you're stacking...
I ordered the 1/2" plate pieces with round holes from SendCutSend. The main tubes are 2x4x0.25". Installed a zerk in the forward pivot (which I machined from a piece of bar stock), so all the pivots are greasable.
Happy to finally get some use out of the 3rd function kit I had the dealer install when I bought the LX 2 years ago.
Reactions: 6 users
5,129
That is way cool man! (y)(y)(y)
Got any pics of the fabbing up?
GrumpyFarmer
5,042
That’s awesome. If you lift the loader up and roll the forks all the way forward how does that do plucking rocks and large rounds of wood? Keep the pics coming. That seems like very functional and from pics pretty clean fab job. 👍
Showmedata
LX3310
May 18, 2022
210
200
Boulder CO
Parts from SendCutSend - 1/2" thick, no way I wanted to cut those myself.
Most of the raw material, all from the drops zone at my local steel yard IMG_6038.JPG
Welding table = sheet of diamond plate on my table saw
Light saber action. Someday maybe I'll learn to get cleaner cuts with this thing...
Main pivot housing I turned out of a 2" dia steel bar stock. Boring out the 1" dia hole was an exercise in patience on the lathe.
Mocking up the mounting. The tabs on the vertical tube were my original plan to mount it to the pallet fork frame, using a plate on the back side to clamp it in place. I failed to notice that the frame's horizontal beams are different thicknesses. In frustration, and not wanting to go buy longer bolts, I decided to just drill & tap two holes in the frame. Since the arm is mostly pulling against itself (unless I tried to dig with it), the forces trying to rip it off the frame stay pretty small. If I'm wrong and that attachment fails, I can go back to the original plan.
That aluminum pivot pin is just for mockup, the steel pins hadn't arrived yet.
I capped off all the tubing to slow down corrosion, since it will live outside. You can see the pivot housing welded to two ear tabs attached to the arm tube. I put a zerk in that pivot housing for greasing.
A detail not shown: I made all the pivot pins non-rotating in their outer mounts so that the rotation would only happen in the close-fitting and lubricated inner sleeves (the pivot sleeve I made, plus the
ones on either end of the hydraulic cylinder).
Also not shown: thanks to a boneheaded lapse on my part, the 1" dia holes in those 1/2" thick parts were excessively faceted (polygonal) and not round. I had to buy a cheap adjustable reamer to clean those up. Couldn't use a twist drill because the material removal was too small and it just bound up rather than cut.
5,129
Most of the raw material, all from the drops zone at my local steel yard View attachment 128814
Thanks for the write up and the pics.
I love the talent, and ingenuity I regularly see on this site.
You are clearly very talented, thanks for sharing. (y) 🍸
6,246
NICE.....
FWIW. drill a small hole in the arm end, squirt oil or spray rustcheck or similar, then screw in a selftapping screw. Over time , heat will drag the oil here ,there, everywhere inside the tubing.
2,941
For a smoother cut you can figure out the offset from the center of tip to a surface on the cutter (like the white part somewhere). Then you can draw your shape on paper then trace it at the offset onto plywood or something similar and then use that as a guide to follow with your plasma cutter.
Here is an example for circles
Here is a link to tools on Amazon that can help with this:
Showmedata
LX3310
May 18, 2022
210
200
Boulder CO
Thanks. My problem is not so much the guide, it's getting consistent clean cut all the way through the material without the slag reforming on the back side. I suspect it's about getting the current + airflow + torch travel speed balanced correctly; I haven't spent much time really working on this yet.
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
578
989
I've just found this thread - your grapple looks great. I was moving some logs today with one of my daughters with forks, and a grapple like this would have made it much easier to load the logs. I'm thinking I'll make something similar for mine.
If you're still there, now that you've had the grapple for a while, it's there anything you would change ?
Showmedata
LX3310
May 18, 2022
210
200
Boulder CO
Hiya.
2 full seasons of use on it now and I'm very happy I made it.
I occasionally think it'd be cool to have a second pivot with a second cylinder (think elbow joint added to the current shoulder joint), but that's a lot more complexity and weight. As it is, the weight is right at the limit of what I can lift and maneuver without mechanical assistance. I had to remove it once this summer so I could use to forks to lift something that was both heavy and tall; if it weighed 50lbs more I would need a hoist to position the thumb on the forks to be bolted on and that's a major PITA.
It's holding up just fine and seems to be plenty stout - no hint of bending anywhere, and I use it to scoop 300# logs regularly. Probably over-engineered but better that than under-.
Paul Allwood
Jul 8, 2025
578
989
Hiya.
Thanks for replying. That's all good to know.
Bearcatrp
Mar 28, 2023
1,312
959
Minnesota
Looks great. Been thinking about doing something like that but different. Instead of hydraulics, mounting a winch that you use on 4 wheelers/side by sides. Remove the pulley, mount some kind arm. Would mount in center so the arm goes in between forks. The arm would be curved. Just a thought. After seeing this post, may try it this summer.
