Hi, can someone help me figure out how many HP Kubota 1402 actually have?
The name suggests 14, BUT according to most of sources I have found on the internet, it says 18 or 19 HP
Says 13,8 HP here
here it says 19 HP and 14HP at PTO. I assumed in total it as 19 but if you use PTO, 14 goes to that and remaining 5 is used for moving the tractor?
Another source stating 19HP
On this list it appears as 13 HP. It is strange that for similar model B1400 it says 19HP and for 1402 it says 13HP.
Can someone help clearing this out please? Is there a way to test it? The reason it simportant is because I am thinking of replacing it for a stronger tractor of around 20-26 HP. Now if I already have 18 HP on this one, then it won`t be much of an upgrade, but if I own only 14 HP now, then it makes sense to upgrade.
Says 13,8 HP here
TractorData.com Kubota B1402 tractor engine information
www.tractordata.com
KubotaSub-Compact Utility Tractors B02 Series B1402 Full Specifications
Here we provide full specifications for KubotaSub-Compact Utility Tractors B02 Series B1402 manufactured on 1985
machinerylink.com
Kubota B1402 utility tractor: review and specs - Tractor Specs
Kubota B1402 review and specifications: dimensions and weight, engine and transmission type, horsepower, oil type and capacity, tires
www.tractor-specs.net
TractorData.com - Kubota farm tractors sorted by model
www.tractordata.com
