Tires for my B8200
GrassLakeRon
B8200HST-DP , RC60-82h Mower Deck, Woods RB6 Rear Blade, Homemade Carry All
Oct 27, 2023
323
194
Brooklyn, Michigan
Hi all,
I'm looking at replacing my tires on my B8200. I was looking at the Titan All Weather 13.6-16. Has anyone had experiences with these tires? Do they rip up soil? I was also looking at the OTR 24x9-12 for the fronts. Anyone with experience with these? Do they rip up soil? I mainly cut grass, but my property has rolls.....
Thanks for your insights.
Ron
11,261
Those are top tier turf tires, doesn't get much better than those.
They shouldn't rip up soil.
11,261
Rear choices
Front choices
These are slightly smaller (not an issue with ratio)
Same height but 1" wider which might make mounting and profile, interesting as the rim is meant for narrower tires.
GrassLakeRon
Oct 27, 2023
323
194
Brooklyn, Michigan
Rear choices
Front choices
What are your thoughts about BKT?
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
124
Glendale, Rhode Island
I ordered a set of BKT's. I will give a review when I get them on.
You didn't mention whether your tractor is 2WD or 4WD. If it is 4WD you will want to maintain the circumfrence ratio between fronts and rears as was the original. This is because you want the fronts covering slightly more ground than the rears to maintain steerage. "Pushing" the fronts is not a good idea. I have attached the original specs for reference. Good luck with the new tires!
GrassLakeRon
Oct 27, 2023
323
194
Brooklyn, Michigan
Thank you. I have read a lot of reviews and forum posts about BKT tires. I hope to have them at least half as long or more then what I have now....from April 1989!
