I tested and the link is below. With the speed control open, raising the 3pt, it will not hold its position and shakes. https://photos.app.goo.gl/uzwqk3c7jkKWQndv6Everything as normal except your comment on the lowering speed valve. You start by saying valve is open and then you say it won't lower unless you open it. That is contradictory. Was the test run with the lowering speed valve open or closed? It should be run with the valve open.
Need a much fuller description of this test. What happens at each of the first three positions.
Jerry
