B7100D hydraulic system
koscocos
Seaford
I just had the 4 hydraulic cylinders repacked on my kubota B 219 front loader. I also drained out the hydraulic fluid, cleaned the filter screen and replaced both low pressure return lines. After putting everything back and filling the hydraulic tank to specs, can I just start it up to build up pressure or do I need to bleed the system first? Thanks!
3,637
Start engine and run all cylinders full out and back a couple times. Done.
