SSQA for BX Series (BX2370 Skid Steer Quick Attach)
WI_Hedgehog
Apr 24, 2024
770
1,020
Milwaukee, Wisconsin, U.S.A.
I have a new-to-me 2017 BX2370 with pin-on bucket; from what I understand SSQA (Skid Steer Quick Attach) was not available in 2017 as an OEM option, and in fact I'm finding it difficult to find information on adding SSQA to the BX Series tractors.
I found threads on D-I-Y SSQA, though before rolling my own I'm wondering if quality/affordable pin-on SSQA adapters exist that fit the BX2370 FEL (Front End Loader).
Purpose: Adding a SSQA
  • Stump Bucket
  • Root Grapple
  • combination 2" Receiver (for a ball hitch) and Post Puller
  • and SSQA adapter to the existing bucket for ease of use.
5,779
curious, what loader model is on your BX2370 ?
My 2018 BX23S has the LA344S, s means ssqa is on it( 7J62636103 ).
Those that work on the little beasties may KNOW if it'll fit or not.
You could lookup the loader drawings, compare part numbers for with the LA344S.IF your bucket is the same as the nonSSQA loader , I suspect the adapter will fit fine.
If not, make your own from 'kit' of the SSQA lever/end pieces and some 1/4" sheet steel
or
goodgle 'bx2370 ssqa adapter' ??
add to your list .... pallet forks !!!!! super handy
WI_Hedgehog
Apr 24, 2024
770
1,020
FEL: LA243
I tried searching this forum and general Internet searches and came up short on the BX23 series SSQA adapter, though it could be I'm going about it wrong. Finding SSQA specification diagrams and weld-on locking leaver wasn't difficult, but I'd rather not design/build my own wheels if there's a tire store down the road... (I'd rather buy a well-designed SSQA adapter than build one if the price is reasonable)
Speed25
L2501(sold) - BX25D
Apr 23, 2024
269
413
NC
The stickers on both say "Worksaver" and their website lists #835130 as the part number as noted above. Lots of dealers/retailers it appears, so price one out near you and let us know about pricing and availability.
9,184
3,979
Sounds like a worthy project to me.
Since there seems to be a decent amount of options, The hardest part is probably going to be evaluating the "Quality V Cost" thing.
Don't forget to take pics as you go. (y)
5,779
Nice find Wolfman !!! A 'nobrainer' to buy and build project.The really hard, tricky part is DONE. I can't make those 2 pieces for $100 and that's WITH getting the steel for free.
They even come with Zerks !!
WI_Hedgehog
Apr 24, 2024
770
1,020
You thinking something like this? https://asktractormike.com/product/kubota-sub-compact-quick-attach-conversion/
Reasonable cost might be a bit subjective...
Thank you for starting this off. What @GreensvilleJay posted is exactly what I'm looking for, though a BX is tiny compared to a LA, so fitment is a concern. If that SSQA was available in a smaller BX version for $400 or less I'd buy it. It's obvious the quality is top-notch, and way more than the BX needs.
If not, two of the brackets @North Idaho Wolfman posted are a starting point.
Soopitup
BX23S
Oct 25, 2018
369
164
New England
I believe the 70 and 80 series loaders have the same pin locations but I can't verify.
IF they are the same, the "difference" is in the pins and how they attach.
Some/most of the 80 series loaders have a attached stand that effects how the pins are shaped/mounted.
IF the pin locations are the same you should be able to use the Kubota SSQA adapter(or any aftermarket version?). You may have to figure a pin solution though.
Soopitup
BX23S
Oct 25, 2018
369
164
New England
This is my thread on installing pin on pallet forks to a SSQA loader. This should help if the pin locations are the same.
However, the pin on forks I used were also for an 80 series loader, not a 70 series. Keep that in mind.
These are the pallet forks I ended up using.
On their site Redline list them as being compatible with all? BX models (scroll to the bottom of the page).
IF that is the case then the pin locations are the same across the board and at worse you'll just need special pins (like I did) to mount. Best case you can use the ones you already have.
WI_Hedgehog
Apr 24, 2024
770
1,020
Seems I confused the Kubota LX series tractors with the LA243 FEL, @GreensvilleJay posted exactly what I'm looking for. They're spendy, however higher quality appears to be the reason. There's a nearby dealer that carries them so I'll look this week.
Worksaver adapters for single cylinder loaders allow using “universal” skid steer interface impliments. Built with 7-gauge material to provide strength yet keep their weight under 70 lbs. for maximum lifting capacity.
3rd Function Kits aren't inexpensive either. Does it make sense to plumb in a manual foot pedal vs. relay-operated Summit kit (for a grapple and other FEL attachments), or is the hydraulic pump output small enough on a BX23 it won't matter? I'm thinking there must be good reason owners use buttons in the stick vs. a foot control.
3,979
I'm betting that the "stick controls" are there because the foot area is pretty crowded on HST models.
That would be my guess anyway.
5,779
A mechanical foot control would be 'interesting' to design and install,could be a royal PITA and need some kind of spring return, 6 way diverter valve.
An electrical one just needs a real good 'industrially rated' foot switch,one totally sealed, impervious to water,dirt,mud, slime and other 'yuckies'.
Stick mounted switches are easier to mount, cheaper to make,offer a 'universal' solution aka 'one size fits all'
9,184
The company that is making the foot control 3rd function control has a video of the install, and on a BX it would be quite the feat.
The hand controlled 3rd is a much better system.
jonesc00666
BX25D
Aug 22, 2018
texas, texas, USA
So when I went thur this on my BX25DBL I ordered the ones for BX80.
2 LEVER QUICK COUPLER BX80-LA344
SKU: KUB-BX2410 $518.00 1 $518.00
The cheepest place at the time was Hoober inc. They were 550plus shipping at the time. Found them by searching for BX2410. it has been amazing having forks.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
269
413
NC
Everything bolt up properly? Pictures? I've wondered if this was a direct swap for some time, just haven't had the chance to measure the 70 series and 80 series to compare.
