I have a Z726 zero turn mower with the Kawasaki FX801V. After mowing for about anywhere from 15 to 45 minutes, it starts to stall and cut out. Choking will keep it running for a bit until it just dies out. After sitting for awhile, runs fine and then starts the process all over again. I initially changed the fuel pump and same issue. Changed the electronic fuel cut-off and same issue. Put on an electric fuel pump with an auxiliary fuel tank and same issue. Any ideas?
Curious... is the line going to the charcoal canister a vacuum or pressure? Any issues with disconnecting it?
