FDR 1672 mower
mito352003
Paw Paw, Michigan
I was mowing today on a L2501 with a FDR 1672 mower. Unfortunately I very slightly ran over some river rock and the Mower stopped spinning, the PTO Shaft was working not the blades. Also I broke a blade. Honestly it barely got into the rock (size of eggs).
My question where do I look first? I assumed there must be a shear pin but I see none listed in the manual.
Terry
Flintknapper
L2350DT
May 3, 2022
1,767
2,226
Deep East Texas
Terry
Yeah, no shear pin since the input shaft on the gearbox is splined. Also the output PTO shaft on your tractor.
Since the spindles/blades are belt driven and a tensioning pulley used.....IF something is hit that suddenly stops/slows the blades, the belt(s) will just slip.
If the inertia of the belt is great enough.....it can jump a pulley. I've had that happen on my Zero turn when I hit part of a hidden stump.
Glad you got it figured out. Back to mowing. (y)
