Turbine oil SAE 80
Torinodan
T1600, G4200, G5200, Ford 2810, 1974 Wheel Horse C100
Oct 14, 2021
199
94
Fayetteville GA
Do you a have MIL SPEC number? You can see what it crosses to. Or any other spec number?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
790
687
E.
your Mobil fluids depot/professional can get it for you.
similiar to hydraulic oil.
not something PepBoys or similar would carry I suppose.
if you be dead set on using turbine oile then something like SHC 918 which is most modern or VG 32, 46 and 68 are options
I havent heard anyone use the term turbine oil for a lot of years.
most I know refer to it as compressor oil.
5,731
re: The specs for my M4000 say to use “Turbine Oil SAE 80” for the power steering. Kubota here has never heard of Turbine Oil
Hmm.. KUBOTA made the tractor, wrote the manual.....
..almost makes you want to SELL the tractor PDQ !
Torinodan
Oct 14, 2021
199
94
Fayetteville GA
I was curious about the mil numbers and such dealing with turbine engine oils at work. The stuff "expires" and I love anything I can reuse.
5,414
The specs for my M4000 say to use “Turbine Oil SAE 80” for the power steering. Kubota here has never heard of Turbine Oil. What do I use?
Turbine oil js a standard product sold under a lot of different brand names. Mobil DTE is one of the more common ones.
Turbine oil is commonly used in industrial machinery and usually marketed by ISO viscosity grade not SAE. In the Mobil line SAE 80 would be DTE Medium or Heavy Medium. I would probably opt for the Medium. If you only need a small quantity McMaster is a convenient source.
3,528
Is the power steering on a M4000 separate from the transmission…?
2,163
Sleeve bearings on larger electric motors will use that. If there is a large electric motor repair shop on your island they would probably have a drum of it. Or some utility generation plant would probably have it.
FlyingFish
M4000
Apr 18, 2024
Honolulu, Hawaii
Since it's running a hydraulic cylinder can I just use the standard Kubota Hydraulic Oil?
FlyingFish
M4000
Apr 18, 2024
Honolulu, Hawaii
I found the answer in an old shop manual for the tractor: The shop manual says to use Gear Oil SAE 80... see attached. Thanks for everyones help... must have been a translation issue back in the day.
2,163
I would take that description as the transmission sump and tractor hydraulic system. But it is probably the same oil in both tanks (tractor and power steering).
For my L185 the manual requires the SAE 80 gear oil for the transmission sump. Now it is recommended to use something similar to Kubota UDT. I personally use Tractor Supply universal tractor hydraulic fluid.
8,856
Yes you can use UDT as a replacement.
3,528
I’m feeling that Our Opinions…are not equal to “Kubota Approval”….. therefore, while it’s likely just fine to use Kubota UDT or SUDT2, etc…. do not accept that as any “basis of approval”. I think if I owned a M4000… I”d use Turbine Oil 80 if I could find it…(Mystik at Blaines and Chevron Turbine Oils both are found online) …. Failing that, I’d select Kubota UDT….and LAST I’d use 80/90 Gear OIl (because it appears the OP’s finding it in the M4000 WSM probably applies specifically to the transmission. Just my opinion. (and I”m a person who really likes gear oil and keep lots of it on hand for various reasons.)
