B7100 Ignition Fuse Blowing Immediately
Jasonleek
B7100 Tractor, B7510 Tractor, Z242KW-48 Zero Turn, Massey Ferguson 265, Baker F
Apr 16, 2024
10
Washington
I have to figure this out. Where is the starter located on this tractor? I am hoping to not pull all the panels off if someone knows where the starter is by chance.
StephenR
34
Kentucky
Does the fuse blow when you turn the ignition on or when you try to start the engine? A better description of the problem would help with the trouble shooting.
Steve
Jasonleek
Apr 16, 2024
10
Washington
Steve
When I go to start it. I suspect either the starter solenoid or relay are bad?
5,236
1,018
What model of B7100 do you have......HST or manual transmission. 4x4?
Go to this site and download the Workshop manual for your tractor.
It will show you where components are plus has excellent wiring diagram
Books
On the B7100 HST model I do not see either a fuse nor a relay in the starting circuit. Only one safety switch.
Jasonleek
Apr 16, 2024
10
Washington
Books
HST. 4x4. Thanks for the link
6,412
Where is this fuse that your blowing?
Because there is no fuse or relay for the starting circuit of a B7100HST-D
From the starter to the key switch there is a fusible link and from the key switch to the Solenoid there is nothing but a safety switch for the clutch pedal.
Jasonleek
Apr 16, 2024
10
Washington
Its right under the dash piece on the RH side, Either 18 or 19 on the diagram. Everything goes dead. I see in the wiring diagram there is no ignition fuse, I guess someone has messed with the wiring as there are several crimp connectors under there.
6,412
The fuses under the dash are for lights and flashers.
I would follow the WSM and the wiring diagram and chase the wires.
A simple test light will be your best bet.
Mountainman
L2501, B7100, B6000, B21, B1750, B2400, B7200
Jul 10, 2022
233
80
Attalla Alabama
mossycreekoutdoors.com
Check the big white connector that connects the dash side harness to the engine side harness. It's right there where the fuses are under panel right side. I've had a few of those get brittle or have broken plastic and they ground out
Jasonleek
Apr 16, 2024
10
Washington
Thanks, I saw that plug last night has a burnt spot on it, but I was out way past my bed time. I will investigate that this evening and report back. That would actually make sense why things are so weird.
