Kubota B7001 cogs
rustydusty
Kubota B7001
Apr 15, 2024
Suffolk
I need new cogs for kubota B7001 tractor on the front axle as completely worn so I need a spare part number if anyone can help please
10,941
You're going to need to describe what part you need better.
Your B7001 does not have anything called a cog.
rustydusty
Kubota B7001
Apr 15, 2024
Suffolk
A friend was checking the front hub and when he took it off the gearing inside is all worn.i know nothing about tractors at all! Perhaps it's called a sprocket? He said as no oil was in the gearing Box the cogs had sheared off
10,941
Sprockets are for chains.
You have gears with teeth. ;)
Count the number of teeth on each gear.
10,941
First thing @rustydusty is to make sure you have a B7001, a lot of people think they have a B7001 when in fact they have a B7100.
Can you give me the complete serial number that is stamped on the clutch housing by your left foot.
kaze
Kubota B7000 Cub Cadet 1782 Cub Cadet 78D York Three point rake Woods RM 400 mo
This is for the B7000, I have no idea how close if at all it is to the B7001?
Depends on the serial number of the tracktor. I do have a Kubota B7001DT but the serial number falls into the B7100DT series so I can purchase parts in the USA. Messicks in Pennsylvania will have a free parts diagrahm for the B7100DT Or you can try Stavros Sava and Sons in Cyprus and see what they come up with.
