L2350DT Hydraulic Problem 3-PT Shakes
mcnuttja01
Kubota L2350 DT
Nov 19, 2022
50
Acampo, Ca
Looking for some help...
I have a L2350DT with a front loader. I installed the loader a couple of years ago. It is installed "in-line". My problem is with the 3 Point. When I lift an attachment it "shakes" or bounces. They only way to stop it other than lowering is to turn the Position Control knob under the seat to closed. Once closed, I can reopen and then lower the attachment. The tractor is Power steering. manual transmission, and has a FEL that I installed a couple of years ago directly off the pump. As I said before, it has been working without an issue for a couple years.......
7,315
My first thought is the pump is starving for fluid but just for giggles bypass the loader valve and see what happens.
mcnuttja01
Kubota L2350 DT
Nov 19, 2022
50
Acampo, Ca
I am no mechanic let me say that first. But, I have no issues with the Power Steering or the FEL and operating either of those at the same time as the 3 pt. has no effect on the 3 Pt.
One thing I did notice. There are two places to add hydraulic fluid. One between the seat and the gear shift and another at the rear of the tractor. When I removed the cap of the one at the seat/shifter it pushed some fluid out.
7,315
We could guess forever and never find the answer.. Eliminating complications narrows the field.
There are a lot of unknowns in your description. For example is your loader valve plumbed as power beyond and does ot have an inlet pressure reief? Hopefully the answer is YES to both.
11,150
If you opened the fill in the front and fluid came out, it's drastically over full!
And pictures of how you have the loader hooked up to the hydraulics would really help!
That model is different then others of the same series, and does not have the normal Hydraulic block to tap the loader into.
7,315
He said direct connect to pump so apparently DIY and first thing in the circuit. Depending on the plumbing that could interfere with the PS.
3,117
Could it be the dreaded plugged vent tube?
That made fluid come out of the shift lever boots on my tractor while it was running but not when tractor was not running. OP didn’t state running or not…
Would a plugged vent get fluid so air filled (foamy) that it would effect the 3PH?
11,150
Yes and yes, also a leak in the suction side of it will foam fluid too.
Flintknapper
L2350DT
May 3, 2022
2,024
2,579
Deep East Texas
From the factory the FEL and Power Steering share hydraulics (with the P/S having priority)
But I've never had that affect the 3 pt on mine.
IF the fluid for the 3 pt is 'foaming' for any reason that would certainly cause it to jerk/bounce.
7,315
My point is he put the loader valve ahead of the flow divider which gives the loader priority over the PS. Thats not factory and just something to keep in mind.
This could be as simple as a clogged filter but why is it only affecting the 3pt and not the loader????
3,940
2,444
Have you checked that everything in the feedback linkage is intact and free to move smoothly?
Edit, forgot picture
mcnuttja01
Kubota L2350 DT
Nov 19, 2022
50
Acampo, Ca
Yes, I am, aware that the install is not factory. For my older tractor I could not find the "Beyond Block" available anywhere. In fact I had to have the loader built for the tractor. It has been in this configuration for almost 2 years without an issue, so I do not belief the configuration of install is the problem.
There is NO evidence of problems with either the FEL or Power Steering. It is definitely in the 3 pt. Above a Post was made of the Feed Back Lever, this makes sense due to the way it jerks.
The 3pt will LIFT without issue but once it reaches the top I have to completely close the DOWN SPEED dial. Same going DOWN, once I have the 3PT down, I have to close the DOWN SPEED dial or it shakes.
While it is shaking I can operate the FEL and the Power Steering works.
I'll check the FEED BACK lever and circuit tomorrow. TRhat seems to makes sense
7,315
Lpl
I understand all of that and feedback may well be the issue
But here is a fact. With the loader valve where it is shifting any spool interrupts flow to the steering and the 3pt. Exactly what it does and how it does it depends on the plumbing of the loader valve. so the valve presents a complication.
Simple questions which you still have not answered. Is it plumbed with PB and separate tank return or not? And does the loader valve have an inlet pressure relief?
mcnuttja01
Kubota L2350 DT
Nov 19, 2022
50
Acampo, Ca
Yes, I removed the loader from the circuit. Same problem. Loader Valve is plumbed as Beyond, from the builder. I didn't ask the builder if it has a pressure relief. I'll follow up with that question.
Regarding return tanks, I do not know. There are two locations for fluid to be added, over the transmission and over the rear-end. Both locations have to drained when changing fluid, BUT there is only one location with a Fill Level Bubble, that's on the side of the transmission.
Once again I do appreciate the help....
mcnuttja01
Kubota L2350 DT
Nov 19, 2022
50
Acampo, Ca
I attached a copy of the circuit I found in the L2350 Manual. The FEL is attached in-line just above the Hydraulic Pump. I cut the line. I'll send pictures later today. Would a picture of the loader controls help?
7,315
We know the circuit on the tractor. We don't know how the plumbing on your loader valve fits into that diagram. Just post a picture of the plumbing on your loader valve and it will answer those questions.
In the meantime disconnect the feedback rod from the lift arm and see if the shuddering stops.
11,150
You can not "disconnect the feedback:" doing so will make the three point go all out of whack.
He needs to follow the WSM and adjust the feedback linkage properly.
mcnuttja01
Kubota L2350 DT
Nov 19, 2022
50
Acampo, Ca
7,315
Perfect. Your valve has an inlet relief but no power beyond outlet. Its feeding the PS and 3pt off the tank port.
Since its ahead of the priority flow divider stalling the loader will make both PS and 3pt inoperable. Apparently that has not been a problem for you.
it looks like the valve could be converted to power beyond and replumbed as it shpuld be but that wont fix the priority issue. The only way to do that is to move the valve supply to where it should be.
Since you have bypassed the loader and it did not fix the shaking problem the issue could well be feedback related. Adjust the linkage as NIW suggests and see if that resolves the problem. Hopefully it will.
