Kubota B6000 Preheat Switch
bamaboi8116
Kubota B6000
Apr 11, 2024
Alabama
So I started working on my tractor recently after buying a new preheat switch (not ignition/power) switch.....or so I thought. Was wanting all of the buttons, switches, and lights to be period correct or as right as it could be after buying the tractor so that I knew it was all functioning properly and looking correct also. Had some issues removing the glo plug preheat switch and ended up tearing it ALL the way up before finally removing it. At this point I opened the new OEM old stock switch that came only to realize what they sent me was a new OEM old stock headlight switch, not the switch I need. I'm wanting it to look and function properly, but I seem to be having trouble finding the period correct switch at a price well under the $150-$180 ones I've found. Any help with this would be greatly appreciated. Thanks
7,147
What switch in this picture are you trying to replace?
Because there is no preheat switch.
billrigsby
Mar 17, 2015
1,023
208
Florissant CO USA 8213'
www.facebook.com
The screenshot I posted earlier was from www.tracpartz.com, while this one also has four terminals they do not list it for the B6000, nor do they have a listing for a B6000 starter switch, but it is considerably cheaper.
Coleman
According to Messick's this should be the part number but it is discontinued...
7,147
Got it, bill pointed out that it's a start and Glow plug pre heat switch.
And no there is no cheap alternative to that switch.
