Drill Chuck for 1/2" Impact Wrench?
imnukensc
BX2380
Sep 10, 2015
735
669
Midlands of SC
Anyone use a drill chuck on a 1/2" air impact wrench? I need to drill some holes to attach some 6x6 post anchors in some very old concrete. I don't have a decent hammer drill so thought I'd use my air impact. Bad idea? Good idea? Any recommendations?
Dustball
2016 B2650HSDC
Sep 15, 2023
422
281
Hudson, WI
Impact would spin way too fast for concrete and you wouldn't get any hammering action. You'll just burn the tip up and spend way too much time.
I suggest renting a rotary hammer and bit from a local rental place for an afternoon. There's no comparison between a rotary hammer and a hammer drill.
8,831
I agree a rotary is the best for concrete, But because it's air, he can use water to cool the tip and you can turn the speed down on most impacts.
Dustball
2016 B2650HSDC
Sep 15, 2023
422
281
Hudson, WI
I see where you're coming from. I'd be interested to see how the OP fares with this method.
Should point out that the chuck you linked to says it's not for use with impact drivers- it's more of a 'quick-change' application. Not sure why they distinguish between an impact wrench or an impact driver.
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
319
169
Eastern PA, USA
I just bought a corded milwaukee hammer drill on fb marketplace for $40. It's not SDS but it did the job. I needed to drill about 60 holes 6" deep and 1/2" diameter in concrete that was poured in 1964 to stick rebar pins in a retaining wall I was putting up.
Totally worth it. Check out the used market. Everyone is going battery these days, corded stuff going cheap.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,632
1,898
Near Lancaster, PA, USA
Without more information, My choice would be an SDS rotary hammer It'll make up to 5/8" holes in concrete in a jiffy.
lynnmor
B2601-1
May 3, 2021
1,589
1,353
Red Lion
For a one time use I would get a cheap corded Harbor Freight hammer drill. If it dies they will give you a new one.
3,510
This is what I did to drill 1/2” holes in rock…. 34 of ‘em…. a foot deep. Worked fine…. Bauer Hammer Drill…. good tool.
6,932
I did this for some project years ago. Rotary hammer. Maybe $60-70 (?) with bits and coupon.
Gotten several uses out it since, so consider myself ahead of the game.
4,966
I have an old Milwaukee spline shank rotary hammer that can be operated with or without rotation. As others have stated, that’s the type thing you really need.
Thing I’m not getting about how an impact wrench would work is the “hammer/impact” part of a rotary hammer and impact wrench are totally different. For a rotary hammer the impact is front to back, more like a Sawzall than an impact wrench. I can turn the rotation off on mine and use it with a chisel or bull point as a small demolition hammer. It’s that jack hammer chiseling motion of the rotary hammer that allows it to efficiently punch holes in masonry and stone.
An impact wrench hammers in the plane of rotation. That’s great for busting a stuck nut loose but doesn’t do anything but spin a drill bit against a concrete slab.
Rent, buy, or borrow a rotary hammer.
3,712
I don't think its a "bad" idea necessarily, but what is the advantage to using an impact?
A rotary hammer drill "pounds into" the work, but an impact won't do that....At least all the impacts I have ever owned did not.
Anyway, IMHO if this is a "limited use" tool, I would go with a HF special.
Smokeydog
Jun 2, 2020
757
728
knoxville, Tennessee
Not particularly for the OP’s application but I had to drill some 5/8” holes in a TLB subframe to mount an attachment bracket. Frame about 1/2” thick. Not reachable using a drill and would have required extensive disassembly. Used pneumatic impact wrench with extensions and universal joint to drive a holesaw. Removed the center drill bit, In a scrap plate of steel drilled a 5/8” hole for a holesaw guide and clamped this to the frame. Liberal use of cutting oil it drilled holes surprisingly easy and quick thru the frame. <1 minute per hole.
Have used the guide block and holesaw method to drill holes in thick metal several times. Re-bore worn egg shaped holes for a larger bolt.
3,510
I don’t see an advantage… but I see a potential DIS-advantage….. Damage to the Impact Wrench due to lateral-effort (pressing against the object) ….applied to a tool designed primarily to impart “torque”. The tool is not designed as a “hammer”.
(I can’t tell the number of times I’ve instructed my family members to Stop using the Incorrect-Tool for the job…. I.E., using a screwdriver as a chisel…. or pliers to twist a hex-head fastener… etc.)
