Found this in the driveway where I had parked my BX23S. I have no idea where it is from. Any suggestions where to look, I have looked in many places.
Nope, that is the old one. I did check out what tools I will need to remove the old one, and it is a 7/8" deep socket and a 5/8" or 16 mm tubing wrench. Holding the steel tube with the tubing wrench and spinning the top of the fitting with the 7/8" deep socket it will come apart. I am inclined to loosen all the pipe fittings first, then remove the two outer retainer bolts, and then finish unscrewing the 4 tubes from the part. Reverse to put it back together. Unfortunately with arthritis in my hands, I will need a helper to do the R&R. It is a project for a warmer day.Damn!
That's the new one right? You should tell him it broke during assembly and ask for another one!
I haven't taken my loader off yet. I need to one of these days just to see how it goes.
You're right. I got the 2 mixed up.Nope, that is the old one. I did check out what tools I will need to remove the old one, and it is a 7/8" deep socket and a 5/8" or 16 mm tubing wrench. Holding the steel tube with the tubing wrench and spinning the top of the fitting with the 7/8" deep socket it will come apart. I am inclined to loosen all the pipe fittings first, then remove the two outer retainer bolts, and then finish unscrewing the 4 tubes from the part. Reverse to put it back together. Unfortunately with arthritis in my hands, I will need a helper to do the R&R. It is a project for a warmer day.
I think that if I told them that it broke during assembly they wouldn't offer another. The part sells for $225 +- on the Messicks website.
