L3130 lost power steering??
10,979
Will do thanks for replying was told when engine stalled could have rotated backwards causing a relief valve problem had wheels up before removing cylinder cycled only couple times raining now will post later thanks again
It's more likely that it has trapped air in the pump and caused it to cavitate.
A lot of times, just burping it the way @GrizBota said will do the trick.
3130
Al
Lifted wheels up with FEL cycled wheels 12+ times let wheels down no power assist fluid levels are good needs new filter so going to change tomorrow and try again Left lift up one night no help left wheels up tonight thanks for help
GrizBota
Apr 26, 2023
1,147
733
Oregon
Dang. Too bad it’s more serious than that. Good luck with it.
3,652
2,074
Check the large suction hose going to the hydraulic pump. It's on the RH side of your tractor's engine.
See if it is wet or has any cracks in it.
3130
Al
I've had pump off that hose looks good all original and dry opened pump to look inside nothing obvious stood out will probably go back in to look for relief valve stuck spring or something
7,201
I am old fashioned when it comes to diagnosing problems
If PS is not working I would disconnect the PS supply line at the steering valve and check the pressure and flow.
