Hello, I have an issue on my SB10 blower I can’t seem to diagnose. Snowblower operates normally unless it is raised to above “7” on my 3-point control lever. Around 7 there is a loud rattle from potentially the gear box or auger. If the hitch is lifted any higher it will shear the PTO shaft shear pin.
with the tractor off (PTO disengaged) and the hitched raised all the way I can easily spin the blower and shaft by hand and no noise is heard. The shaft is the proper length and not bottoming out when fully raised. Any help would be appreciated!
I took the guard off the shaft and recorded a video of the issue linked below.
https://youtube.com/shorts/YCQELhkVekQ?si=Ntlj0mQY8bbS_Et5
