The 22bx version is - https://kubotabooks.com/AutoIndex/index.php?dir=Mowers/Is there an online downloadable workshop manual for the mid-mount mower RCK60B23BX?
I need to know which setting to use for the anti-scalp wheels. I normally set the cutting height adjustment to 3 3/4.The 22bx version is - https://kubotabooks.com/AutoIndex/index.php?dir=Mowers/
what specifically are you needed help with?
You don't need the workshop manual for that you need the operators' manual.I need to know which setting to use for the anti-scalp wheels. I normally set the cutting height adjustment to 3 3/4.
My manual for the deck says to adjust them ¼" ~ ½" off the ground.I need to know which setting to use for the anti-scalp wheels. I normally set the cutting height adjustment to 3 3/4.
See if this helps. Not an exact match but closeIs there an online downloadable workshop manual for the mid-mount mower RCK60B23BX?
