hello, I was just out feeding animals with my l3901 and while traveling on the road in "H" at 2500ish rpm the tractor stopped. If I put it in "L" and very very gently depress the pedal I could drive up the road. Once on flat land "L" and "M" would work if I was very gentle with the pedal. If feels similar to when the relief valve opens if you press the pedal too far with not enough rpm.
fluid level is good.
Anything recommendations on thing to check prior to a dealership call?
thanks.
thanks.
