Kubota L345dt starting issues
Avery
kubota
Feb 19, 2024
California
Finally took the injectors out, tested each one while turning the tractor over got a nice spray out of each one of them. I didn't hear any popping noise. Should I still have them rebuilt? (unfamiliar with diesel engines) Thanks
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
707
328
Herald Calif.
Have you ever had this engine running? Typically you would not have four bad injectors.
Avery
kubota
Feb 19, 2024
California
Yes, I've had the tractor for 20+ yrs in running condition but getting tired. It had only been a couple of days since I had used it and it wouldn't start. I've been posting questions for the last week or so trying to trouble shoot the problem so I took the injectors out. thanks
11,199
So if the injectors are working and sounds like your getting fuel out of the injection pump, the next would be glow plugs.
4,238
While the injectors are out…. perform a compression test.
Avery
kubota
Feb 19, 2024
California
Should I check the resistance in the glow plugs before I take them out with the power wire off? What should I torque the injectors at? I don't have a manual Should I put anti-sieze on the thread? Thanks
11,199
Yes take the buss wires off and check resistance of each one.
NO anti seize, just the sealing washer.
