RTV-XG850 speed
CourtR
Ontario
Hello, has anyone been able to figure out how to get more top speed then what they offer from factory with out engine cutting out?
3,654
Sure. Buy a Kawasaki Mule.
(Kubota limits their RTV’s speed because of the engineered suspension required safety-margin. Some regions have regulatory restrictions they must meet.)
#40Fan
426
286
I don't know.....the Mule I had was limited to 25mph.
I'm sure there is someone selling a device that will remove the limiter. I'd be a little hesitant because you could easily over-rev the engine.
5,801
From what I've read here, getting the gas INTO the cylinders and OUT of the oil sump will help. They seem to have a 'problem' engine.
Really though , if you can go faster than 25MPH off-road, use your 'daily driver' as you must be driving on a pretty good road.
The easy way (well for me ),if you're a bit computer savvy, reprogram the limits in the ECU ( the 'computer' ).
Hard way, install an 'under drive' unit.
3,654
”Mules” have different models… Ours runs almost 50 mph. It has fantastic suspension…but I consider that speed a roll-over hazard. I don’t recall how…but my son has programmed a “speed limit” into it which limits it to 25 mph for when HIS son…my grandson… drives it. (maybe that’s a factory option…? maybe yours is inadvertently “set”….??)
