2023 L3302 no crank
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
My L3302 with 40 hours won't turn over. I have checked the battery, Ground, fuses, main and slow blow, Seat, pto, hydrostatic control pedal, parking brake, switches. Still nothing. Oil pressure light and battery light are on. Does anyone have a suggestion? Thanks
7,233
Dollars to donuts its one of the things you have already checked.
Double triple check all of the starter interlocks.
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
Dann
Thanks for the reply and your time. I have checked them at least 2 times. I agree this is the likely issue. i have searched the topic many places and everyone says the safety controls signals are the issue. One additional note the 5 amp Starter (ST) fuse in the block goes hot with the key turned to start and goes off when the key is released.
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
Do you know where the Main ECU is located on the tractor. I can verify the wiring from the pin out on the Main ECU?
6,285
simple test...
can you jumper the starter +12 to the 'start lug' and get the starter to spin ?
if so battery is good, it's 'something' between battery and the 'start lug'.
If possible get the WSM for the wiring diagram !! otherwise you can spend hours chasing the wrong problem !!
OntheRidge
Nov 1, 2020
495
588
My 2 cents, and I get the wanting to fix it yourself thing, but a 2023 with 40 hours should be under warranty.
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
I agree. However its out in the boonies. I only have one tractor, so i am trying to fix it or else i have to find a transport etc.. Thanks for the time.
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
simple test...
Yes i have the WSM and it is helpful. I will try the jumper on the starter. I am leaning toward a relay under the rear bonnet. Thanks for your reply and time.
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
I found the Main ECU. Square behind the steering wheel under the rear bonnet. Has the pins in and receives the safety control signals? I am trashed trying to figure this out. Leaning toward a relay? I will try again tomorrow. Thanks for your kindness and time. I will reply with the solution when i find it.
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
Interesting. The fuse gets hot but doesn't blow? It kinda makes me think that the starter solenoid or starter has an issue.
See @GreensvilleJay 's note for a quick test/jump of the starter. Do you know how to do that?
7,233
If the L3301 is anything like my L3901 getting to those contacts is not.as simple as opening the hood. When mine was dead I took a quick look and decided it was not worth the effort.
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
Hey I know you’re right. I don’t even want to go through it. However I have studied the parts breakdown and schematics. That is helping me too. Even though it’s under warranty I want to know what I have enough to fix most things myself in the field so the exercises are valuable and when I find the issue I may make Kubota do that work. I am making a video of my work for documentation so I can remember what I did. Thanks for your time..😉
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
I got it fixed. Started right up. The wire from the starter relay unit to the starter was a bad crimp on the started end. 50/50 contact. Fixed the crimp and bingo. Thanks for your help. 😇
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
Did you jumper the starter as suggested? Results?
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
Thanks to everyone for the help. I am just learning farm life and tractor talk hope this thanks everyone.
2023 L3302 Nocrank = Bad crimp on starter relay connection to the starter solenoid. Not enough copper vs plastic.
5,304
Thanks for updating us. It's always nice to hear the results/conclusions when someone has a problem.
Winkeye
L3302
Mar 19, 2024
12
9
Kentucky
I replied to this before but I can’t find my reply. The problem was the starter relay wire had a bad crimp. Thanks for you help.
