L series side panels
Don Br.
Kubotal2350dt, disc, rotary mower, fel
Mar 4, 2024
19
Oklahoma
I Purchased an l4300 DT a few weeks ago. It’s a nice low hour tractor but it’s missing the right hand engine side panel. Somehow it came off when the guy was mowing and he accidentally ran over it with the brush hog and destroyed it. Having trouble finding a used one. A new one from Kubota is around $1100. I don’t really want to pay that! I was looking at the L 2600 and l3000 side panels. Does anyone know if these will interchange with each other. They look identical. The only difference that I can see is that on the 4300 it has a little notch cut out at the bottom right side. I looked at my tractor and the only reason I can see for the cutout is that the radiator drain plug is right there behind that cut out. If that’s the case, you could just remove the side panel to drain the radiator. And if the notch had to be there, a sheet metal shop could probably cut that out for you. I was wondering if anyone knew if those were interchangeable as far as the physical size. Just looking at the pictures they look identical. Might be easier to find one if you had two other choices. A guy could just change out the decal.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,888
2,302
Western MT
I'm not sure the pictures show how it really is, but I'd consider taking the other side to a fab shop to see if they can make one for a reasonable price that is close and buy a can of spray paint.
Don Br.
Mar 4, 2024
19
Oklahoma
Its hard to tell by looking at pictures as far as the actual physical size. But they sure look very similar in the pictures. Yes, I have even thought about having one made at the sheet-metal shop. Could probably do it cheaper than $1100.
But if they are the same, I would probably have a better chance of finding one of the three.
4,060
There are a lot of 3-D printers who can make one of those fairly priced and quickly.
2,842
Go to this website https://apps.kubotausa.com/illustrated-parts/
or to Messicks dot com
find the part number for what you need
then go to Messicks and search “Kubota ###” using the part number
you may have to go to the newer part number but eventually you’ll get a page that shows the part and in the lower left area is a place where you can see all the models that part fits.
Don Br.
Mar 4, 2024
19
Oklahoma
Thanks. I’ll certainly try that,
Don Br.
Mar 4, 2024
19
Oklahoma
I checked on messicks. The 2600 and the 3000 are the same, they have the exact same part number. The 4300 is one number off from that part number. But, it will have a different part number even if it’s the same size because of the notch cut out in the bottom of it. I just need to look around and see if I can find a 2600 or 3000 tractor and measure the panel.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Might be able to find someone on here to compare measurements with.
Seems like there’s a fellow that posts occasionally with a B boneyard that also has a few Ls? I think I saw such a post two or three weeks ago.
Or maybe it was another member that posted in the B thread about having some scrap Ls. Couldn’t find that exact thread, but here’s a similar one.
B Series Salvage Yard
2,842
You should contact @007kubotaguy and see if he has any of the parts you need. He runs a parts recycling company (junkyard) of older Kubota parts.
there is a private messaging system on this forum that you can use to send him a message. Envelope in the top right corner is where you start (on my browser anyway)
Don Br.
Mar 4, 2024
19
Oklahoma
Thanks. I’ll check with him.
johndeerebones
B7200 HST-D RC-60-72, L4200 GST MFWD with FEL
Aug 17, 2020
109
Do a quick google serch there are many tractor salvage yards throughout the US.
Don Br.
Mar 4, 2024
19
Oklahoma
Another reason I’m thinking it’s the same panel even though it’s a little longer tractor is that I noticed they used a spacer between the dash and tin on the 4300 and used the same size hood and panels for all 3. The 2600 and 3000 don’t have the spacer. I think I located one from a 3000. I’ll just see if they’ll measure it for me.
10,622
Yes they are the same length.
You know there were probably 100 times more L4300's made than the L3000's and L2600's combined.
Don Br.
Mar 4, 2024
19
Oklahoma
You would think a guy could find a used one. Haven’t had any luck yet. Of course I’ve found a left side, but I need a right. Maybe the right side falls off easier! Lol. I’ll find something eventually.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Good eye. Other than the sticker and radiator drain notch, I think you’re right, they are all the same part.
I suspect you’ll have one shortly with your efforts.
Don Br.
Mar 4, 2024
19
Oklahoma
Yeah, now I have more choices!
2,842
Great thread!
@Russell King I've used that idea many times - Neil M has put a lot of effort into their computer systems.
Kubota site used to have a similar function but it is not available on my iPad and I haven’t used a PC to look for that functionality in a year or so. I just use Messicks more now since I can also get a price from them that is similar to what my dealer will charge
