When is additional weight too much weight?
11,093
Kubota tells you not to do this!
I would say it's too much weight!
So yea I say overkill.
4,211
Fifteen Minutes Wasted out of my life …i’ll NEVER get back…. 🙁
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
355
235
Eastern PA, USA
I have a question. Why not? The weight isn't on the axle, it's on the tire. It adds to traction. I have a tractor with these, and 2 with washer fluid. Also you dont' have to watch the whole video to figure out what he's doing, you can skip ahead.
leveraddict
Apr 1, 2019
905
594
NEPA
Yes Kubota says loaded tires are a no no on the BX23S backhoe model, but the 2380 has no backhoe! Not sure if this guy has weight on the 3 point but if no then why not wheel weights? Not that those two weights amount to much I would say he doesnt have enough weight on the rear of that machine for loader work. When I do loader work I have my BH on which is 600 lbs! Im going with underkill! LOL!
4,211
Oh NO! … if you Skip Ahead…. You may miss CRITICAL DETAILS of his Unique Method! The shift of that camera-angle was Very Revealing! …not to mention his insightful commentary about the particular use of a Swivel Socket!
6,291
Those weights only add 100#, 50 aside, so what's the 'big deal'?
Tire/rim/rimguard is 128#, so now 128+128+100= 356#
Curious as to what stock tire/rim weigh, what rimguard weight is ?
The BX23S BH is 600+ pounds,so he's still weigh under 'spec'.
At least his video was in 'real time'. NOT like other that show a 15 minute job in 2 minutes !!
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,317
827
under a rock
I didn't watch the video.... I can't stand some of these youtube yahoos...
Anywho, my BX23S came from the dealer with Liquid calcium/ballast in the rear (turf) tires.
I recently bought a second set of R4 tires for winter/spring ... NO Ballast.
I don't see a difference in traction or stability ... For MY USE.
I actually drained out most of the liquid from the turf tires.....
Now I can swap tires without getting a Hernia.
4,211
I much prefer videos that “get straight to the point”….. instead of long-winded introductions by producers who think we want to what THEM instead of the subject at-hand.
I am glad my tractor (which I bought used from the 2nd owner) had never had it’s tires filled with anything but AIR. I can do it if I choose….but have no need for it… and I know there’s no internal damage to the wheels/tires as the result.
I AM surprised to see that the rear tires are larger than standard.
This M4700DT …had a larger/more-hp brother….the M5400DT… Identical tractors except the M5400 governor was set at a hundred RPM MORE…to give it a few more HP… and the M5400 also had a wider rear tire…(16.9-28) vs the M4700 14.9-28) …but the same front tires (9.5-22)
The selling dealer (a Kubota dealer in Baytown, TX) had upgraded the rear tires to the larger M5400 standard…(16.9-28) when it was first-sold to Owner Number 1. I’m guessing because that area of Texas is known for “soggy low-lands” and perhaps greater flotation / traction was desired by the first owner.
I got this tractor 20 years later…with only 400 hours on it…and the tires still 90% tread.
Very happy owner, I am. :p
5,187
Didn't bother watching the video. The guy's an effin idiot.
I would not consider the guy to be an "idiot", but he is apparently ignoring Kubota guidance (per IWM).
4,211
What “Kubota Guidance” is contrary to adding wheel weights?
6,291
BX23s manual is equally ambiguous !
NO 'maximum' weight for ballast...
Chart for calcium based on temperature but about 100#s per tire
What does 'rim guard' weigh in at 75% tire fill ?
They do say REMOVE the ballast when not needed (aka mowing grass ? )
Also no ballast if BH is on.
BH weighs 600#s, so each rear could have 300# total, His rimguarded tires are 128#, and he added 50# of cast so about 1/2 the equal of having BH on, unless I'm missing something.
Bee-Positive
Nov 16, 2022
1,076
1,001
Amsterdam, NY
For my BX1880 the UM states:
Liquid ballast in rear tires
“The weight should be added to the tractor in the form of liquid ballast.”
On the following page it states:
“:To avoid damage of the transmission, do not use the rear wheel weights and liquid ballast at the same time.”
It DOES say don’t add liquid weight the front tires. Also, it doesn’t say anywhere you CAN’T add rear wheel weights. I opted not to get my tires filled.
I had weights (50# each) from the Craftsman 6500 the BX replaced – fit like a glove. I used two 1/2" threaded rods and mounted them without removing the tire. The max mixture of slush free calcium chloride at -47F equals 97# per tire so I think I’m pretty safe with 50# each. And I can remove them easily - just four nuts – for mowing and such. If I need more I hook up the ballast box to the 3 pt.
5,164
The 26x12x12 tires take 8-9 gallons of Rimguard per tire and are approximately 25% heavier than water. The manufacturer says weighs 10.7-11 lbs./gallon depending on who is doing the mix. My local dealer charges $2.25 per gallon, and there is an hourly charge for the installation. It is the hourly charge that makes it so expensive. I have seen many videos showing how it is done with do-it-yourself pumps and hoses. I did check with the service manager, and he said that if I brought the containers, he would sell me enough to do my tires. I have some old tires that were filled with Rim Guard, and I am contemplating draining them and installing the old Rim Guard into my new tires. I will need to empty the tires to dispose of them anyway.
NorthwoodsLife
Oct 15, 2021
1,410
1,475
Wisconsin
My. Beating up the guy in the video. It's YouTube, not Hollywood. Cut him some slack. Ain't no banjoes playing and he's doing his best.
It's a tractor. So, a guy adds weight to it. Is it too much?... Maybe, maybe not. Different applications. I'd buy him a beer and give him a "salute'.
Jeez, we can be so harsh.
If Kubota says do or don't do this, you should follow the directive. But if it's out of warranty, it's all you.
I am not a fan of wheel weights or liquid ballast. Because I don't need it. But if I did... Go For It.
John T
May 5, 2017
1,317
827
under a rock
Gibberish.
4,211
your Literature is for an M4700
we are talking about a small BX
That doesn’t answer the question. My post was only to show that adding weight to the wheel that already had filled tires…is NOT a general prohibition by KUBOTA….as was previously indicated.
—- "Kubota tells you not to do this!”
It MAY be a prohibition on certain models…but NOT a Maker/Brand-Wide prohibition…. and your response, John T, did not provide any useful information…. BUT THANKS TO BEE-POSITIVE…for doing so.
