trial and error
Feb 16, 2023
394
386
NY
Put the homemade loader back on so now we will probably get a late March/early blizzard. Also made the homemade "bucket" attach to the homemade fork frame so no more pinning and umpinning between the two
GrumpyFarmer
4,528
The two deep supers I understand,..... but what are the other two?
Never seen anything quite like 'em.
In previous post…The two in on left hand side are (deep) brood boxes…on the right hand side the one at back with cut outs is the super and the one at front is the base. It’s a Flow hive…it’s basically a Langstroth, however the super is a bit different. The super has cells / cartridges that have a key and when you crack them the honey flows out…it’s a bit less invasive / less labor for us to steal the honey….there is not no extracting or centrifuge or anything…turn key and honey flows out…supposedly…we did not harvest anything last year just tried to have a healthy hive for winter. Hopefully this year we’ll see how it really works.
When it is finished it will look like this (see below) except a different color / paint scheme.
5,185
Quite innovative!
I had bees 50 years ago, and then restarted 8 years ago.
Didn't work for me.
I spend Winters in FL now, and the bees just could not survive my extended absence.
I even bought a nice new electric Maxant 9 frame extractor, that I have never used.
Still have all the mostly new equipment, so hope some family member will pick up the hobby.
GrumpyFarmer
4,528
Quite innovative!
Didn't work for me.
If you drive, you could take them with you…that’s an option. 😂. But I understand. We have two (just added the third place in december) more properties 4 hours away(we’ll retire there soon) and we plan to have bees there. I’d like to put bees there but even at just 4 hours away it’s not reasonable. So i understand from Mass to FL not really reasonable. For now we are trying to learn how to take care of the hive / bees…that part is the same. When we move to next place, we will most likely go to traditional hives as the flow hives are very pricey…I think that beyond 4 or 5 hives the flow hives would not make much sense. I seriously doubt any serious honey producer would ever consider them…ideal for a hobbyist IMO. At least not the way I do math. For now they are pricey but we are learning the basics. 🥃
5,185
I do not think that I could afford to ship the bees + equipment, back and forth.:(
Delta, would likely make it VERY expensive!:D
Bees are FUN,..... for people who are genuinely interested!
What do you expect for colony survivability in Ohio?
GrumpyFarmer
4,528
I really don’t know. One of the mentors in COBA (central Ohio beekeeper assoc…I just went to their bee school)…anyway he is keeping 20 hives and has lost none in past 3 years….lots of others of the lecturers at the org/bee school have lost hives this past winter. I am not even a beekeeper…I have one hive that has not made it through first winter. I don’t even know what I don’t know. 😂. Ask me again in 5 years maybe.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,734
2,174
Western MT
Yesterday, welded the front blade support for my grader scraper.
Today, took the chains off. I can put them on if needed, but we probably won't get so much snow that the Ranger can't handle it.
Also today, used the grader/scraper for 4 hours on the community road. A lot of on/off the tractor to toss the larger rocks out of the road, and had to use the bucket to push a few giant rocks out of the road. Unclear how they got in the road base, but my guess someone putting in/working on underground power lines cut a ditch across the road, and didn't have a problem burying very large rocks in the road. ;)
5,185
[/QUOTE
If you are there year round, to inspect, and tend to their occasional off season needs, you should do just fine.
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
GrumpyFarmer
4,528
It’s a nice sunny day here (41 deg F and breezy)…me and the helpers are playing with wood today.
GrumpyFarmer
4,528
Such wonderful "helpers" !
I use the term ‘helper’ very loosely😉…but you are right they are wonderful…they are great to have around, but they have a tendency to relocate that which has been split and piled. 😆
5,185
Kinda like when my SO complains about the ( Labrador ) hair in the house.....
I tell her to appreciate all the hair, because all too soon it will be gone, and it is just not the same,.... to LOVE a clean floor!
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
We have had a couple of really nice days so I'm finally getting around to building the dollies I need to keep most of the implements in the basement. I did the grapple one a few days ago. Yesterday I built one for the boxblade.
I wanted to build a support for the post hole digger and get it off the ground. Of course that meant getting it off the ground and mounted onto the tractor first. I hooked up the lower links first, the pto shaft next and then used a strap from the PHD over the ROPS to the front bucket. By curling the bucket I was able to get the top link in place and hooked up.
Then used it to plant a couple of 4X4's. After the quickcrete sets there will be a bracket about 5' high on each. A removable 2X4 will slide in there so the PHD boom can rest on it and hold it upright.
Reactions: 9 users
5,436
I have been playing with fire. It took some doing, but finally got the brush piles burning. A little breeze came up & the brush really took off.
View attachment 124408 View attachment 124409 View attachment 124410
Sometimes I wish we could still do that. So many people moved into our county they put a permanent ban on all open burning several years ago. Can’t even get a permit to do it any more. That’s why I have a chipper but that would be a lot to chip.
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
I have been working on the trees/brush for a couple years. There were about 80 acres involved. I’m glad to see these brush piles gone. If the weather is right, I’ll burn again tomorrow.
It is bad when you can’t do what you need to do on your own property. It sounds like you have adapted.
