Hey Everybody,
I have recently bought a G5200 and the G2546A front blower for it. (don't ask me how I found the blower, it took some dedication). Awesome little tractor, D600 3cyl engine really digs in and doesn't miss a beat throwing heavy 9" of snow 40'. Made quick work of my 400' drive.
Anyway, I also just found for pretty cheap a G4200 that had the 3pt kit (G9702) and rear PTO kit (G9703) options and hydro implement lift. (also had G2000 front blade) The 2 cyl engine in the 4200 is pretty weak (compared to the 5200's 3cyl), runs loud and rough, smokes alot, PO said he replaced the injection pump and the machine just looks a heck of alot more beat up. Missing bolts and messed up wiring and whatnot.
Anyway, so I wanted to swap this 3pt setup onto my 5200 and I notice that the 4200 seems to be a few years newer (serial number is quite a bit higher than the 5200), I can see some various improvements in a few areas, but one thing that caught my eye is the rear axle is alot more stout than the 5200's.
I just can't decide if I should swap the whole axle/transmission assembly as one unit or just swap out the 3pt setup, it looks alot more work than I really anticipated to swap the whole axle/tranny assembly. Plus, while I'm sure the 4200 is "newer", my gut says it has lead a lot harsher life than my 5200. Especially after I half disassembled the rear end of the 4200, it had loose bolts and kinda looks like it may have been all apart before. Both have the close to the same hours on the meter (~1500), but the 5200 has an aftermarket meter. I guess I'm just afraid if I swap the entire tranny/axle assembly the tranny's more likely to give out that the 5200's. On the flipside, even before I had the 4200, I was checking of the 5200's design while I was changing it's fluids and checking it over, and that rear axle caught my eye as seeming somewhat cantilevered/stress like design. But I can be a paranoid kinda guy sometimes.
Just wondering if anyone has any experience with their "older" design rear axle being a problem in these G series units, seems they obviously updated it for a reason. I dunno. Worth it?
Current 4200 rear axle, notice the cast housing is wider puting the outer bearing out further towards the wheel. (I've already removed the 3pt, hyrdo lift, pto and related brackets and whatnot)
And the current older 5200 rear axle:
BTW, does anyone know what implements if any, besides the rear tiller that kubota offered, the rear PTO can drive? Seems to not be standard anything, spins as basically engine speed and has a female coupler. Not sure what usefulness it is.
(Recent snow poser pic)
![](http://www.snyderworld.org/photos/main.php/d/63020-3/G4200RearAxle.jpg)
![](http://www.snyderworld.org/photos/main.php/d/63016-5/G5200RearAxle.jpg)
![](http://www.snyderworld.org/photos/main.php/d/63003-4/SnowThrow.jpg)
