Engine oil recomendations
Fmac12
L2501
Mar 10, 2024
North Carolina
Just bought a 2021 l2501. has 90 hrs on it and I do not believe anyone has done a 50 hr on it. The filters look original. No records of any changes. Need to know what engine oil would be best. I am going to dealer and pick up filters And some hydraulic oil today.
thanks FMAC
10,004
In your tractor description on your profile you have it listed as a Ls2501, it's not, it's either a L2501F 2wd gear drive, L2501D 4wd gear drive, or L2501H 4wd hydrostatic drive.
As far as oil Rotella T6 is one of the top recommended, 15w40 is good for your location.
Hkb82
Nov 17, 2021
418
330
Ontario Canada
If it’s covered under warranty I’d probably stick with the oem kubota oil for your tractor. Not because it’s better just incase something happens to motor during warranty they couldn’t blame me for using improper oil recommendations. I’d also consider getting a WSM for your tractor since it looks like you’re gonna be doing some of the work and maintenance yourself. Folks on ott are great with helping and solving issues but nothing beats having a paper or digital copy at your finger tips. Even your operators manual has some of the basic info you’ll want. I guess that is if you got it with the tractor.
Have fun with your L2501 and be safe.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,192
3,498
Above 14°f Kubota recommends 10w30 or 15w40 (my preference is the 15w). I'm sure the 4w would be fine, but I stick to factory recommendation under warranty.
As long as the oil is a diesel oil with API classification of CI-4 or newer (CJ-4 or CK-4) there will not be a warranty issue with using whatever flavor of the approved viscosity (10w30 or 15w40) suits your taste. Manufacturers cannot require you to use their oil.
6,314
thanks FMAC
As per your owners manual:
Heavy duty diesel engine oil carrying an API CJ4 - now superceded by CK4 - service approval.
Viscosity grade 10W30 for all season use or 15W40 for use when ambients do not fall below 15F.
3,808
4,634
If you do not use Factory Authorized Kubota 10w-30, Hell Fire and brimstone will rain down from the heavens, Kubota will cancel your warranty, Christmas will be canceled, and look at what happens when you use an aftermarket filter....
3,808
NAZI…. not NAPA….engineering…
(They claimed the U.S. wouldn’t sell them helium. Back then, TX had the only viable helium-wells…(Amarillo and Ft Worth areas.. In reality, the Hydrogen was more efficient, lifted more weight, and was cheaper and easily-produced.)
Nowadays…Helium is extracted from Nat’l Gas wells.
jaxs
B1750HST
Jun 22, 2023
1,012
779
They say most ballon gas in Texas is controlled by a guy named O'rourke where no one is buying it so he's been giving a bunch away.
3,808
That would be the conservative humorist John O’Rourke..? … (not the liberal “Beto” O’Rourke.)
and I believe that is pretty old info… about back when there was a national helium reserve..which subsequently was privatized?
Helium was plentiful back then but the gov’t (NASA) paid inflated prices for it…. so the reserve was privatized I believe, and helium has since become in-demand for medical devices, space, etc. …for awhile it was feared there’d be a shortage. I think they’ve solved the problem with gas extraction…but I doubt anyone is “giving” it away.
Fmac12
L2501
Mar 10, 2024
North Carolina
I did exactly that. Just got all kubota filters and oil, just to be on the safe side. Was as I thought no 50 hour ,all original filters painted gray. Is now up to date with all new filters and oil.
fmac
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,192
3,498
fmac
The "safe side" went out the window without a 50 hr. service 😉
10,308
I'm one of those fully synthetic nut jobs! 😂 Schaeffer 9000 SynShield® OTR Plus Full Synthetic 5W-40 is my drink of choice in both tractors, the generator and my F250, and that's all year round. The M1078 takes way too much oil so it gets good ol' dyno juice. I run Yamalube fully synthetic in the current outboard and will do the same in the new motor after the 20 hour break-in period.
The tractors get Kubota filters and probably always will.
jyoutz
Jan 14, 2019
3,501
2,591
Edgewood, New Mexico
I use Valvoline super blue synthetic diesel oil 5W-40. I use the oil in my Dodge/Cummins truck and Kubota. I use Kubota filters in the tractor and Cummins/Fleetgard filters in the truck.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,087
1,548
Pittsburgh
OP axed which oil is beast. I've seen some recommendations but no data to support any of the choices.
10,308
Do you ask the manufacturer of your tractor, truck or car to provide the data to support the oil weights that they list in the owner's manual, or the API requirements? It's going to take a long time to get from A to B if that's how you roll. 😂
3,808
Which oil is beast..? Animal-Fat such as Tallow… but when it solidifies it doesn’t pump well. 🤓
Data for the best engine oil is found in the Owner’s Manual and in the Engine Engineering/Production specifications.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,087
1,548
Pittsburgh
Indeed not. I use the lubricant that features the loudest/most colourful advertisement.
Or scantily clad wimmenz.
Further, regarding grade: I use data, factual and anecdotal, from the 1940's and 50's. Therefore, I choose a straight grade such as SAE 50. "If it's good enough for the Pratt & Whitney Double Wasp then it's good enough for my BX23S lawn mower."
