Kubota b8200d
lakemathews
B8200d Kubota tractor
Mar 9, 2024
12
Calif
OK Dan
Extended boom cylinder with bucket up all the way is 43.5 inches from middle of Pin to Pin
Rod is 1.18 thick
Boom outside diameter is 2.2
Boom retracted on ground from middle of pins is 27 inches with bucket on ground d
The top pin is 4inches wide
The bottom Pin is 4.5 inches wide
4,672
The cylinders in your picture are not fully retracted. Looks like an inch of rod exposed so I am going to call itv26" which is what other sources said. If boom fully extended is 43.5 stroke is:
43.5 - 26 = 17.5"
Width for the pins is inside to inside not out to out.
4,672
OK the top pin is 2inches
The bottom is 2.5 inches
The Magister cylinder I linked earlier looks like a good fit. The only way to know for sure is order a pair and try them. If they dont fit send them back.
They are bigger cylinders and will increase the lifting power of the loader. Not likely to break the loader bur it increases the possibility pf making the tractor unstable by lifting more than it can keep upright.
Your other option is to take the old ones to someone that can rebuild them for you.
lakemathews
Mar 9, 2024
12
Calif
Dan thank you very much for your help , I will be in touch after I install the new cylinders
4,672
Good luck. You will not be able to return the cylinders once you hook up the hydraulics. So make very sure everything fits before doing thst.
Your old cylinders had pipe thread ports and the new ones are ORB so you will need new elbows. Cant tell from the pictures what the hoses are but probably NPT so four of these
No thread sealant needed on either end of those fittings.
