Hi, I’ve got a problem repairing a hydraulic leak on the steel pipe lead from the pump to the control valve that lifts and lowers the deck. Problem started when the mounting tab on the steel line cracked and allowed the line to back out of the pump. Was using the machine and noticed a change in the steering. Bought two new steel lines and associated rings from Kubota dealer. Installed new line with new rings and still had leak where lower line goes into pump. Removed line and new ring was torn. Replaced o ring and reinstalled line and it’s still leaking. Used plenty of hydraulic fluid to lubricate o ring both times when installing. Beginning to think steel line gouged aluminum orifice as it was vibrating and backing out. Is there a way to recondition orifice in aluminum pump block or another way to seal joint. Machine is 15 years old with about 1500 hours.
