My tractor has about 1500 hours but the first owner was not kind.
I believe I need to replace the front right seal that is closest to the hub. Any guidance would be appreciated. I have broken too many things when there was a hidden snap ring or a special way to rotate something for disassembly.
First question: On cars and trucks if an axel seal goes bad it usually means the bearing behind it is bad; is that the case with the tractors?
