Hello everyone
Was wondering if there is after market hydraulic cylinders for my loader on my b8200d
I had no trouble finding them for the B1630 loader on my B7200. What model loader and which cylinders do you want to repkace?Hello everyone
Hi Dan, Keith hereI had no trouble finding them for the B1630 loader on my B7200. What model loader and which cylinders do you want to repkace?
I'm kinda done with the dealer, just spoke with kubota hement and they don't rebuild them anymore, just basically said good luck,Hi Dan, Keith here
300 loader and I would like to replace all of them
If you can take a few measurements I will try to point you to some sources. Also a picture of the cylinders so I csn see the construction as well.Hi Dan, Keith here
OK I'll get busyIf you can take a few measurements I will try to point you to some sources. Also a picture of the cylinders so I csn see the construction as well.
Measurements for Bucket and Boom Cylinders
Cylinder bore
Diameter of rod
Diameter of pins
Retracted Length center to center of pins
Extended length pin to pin
Good morning DanIf you can take a few measurements I will try to point you to some sources. Also a picture of the cylinders so I csn see the construction as well.
Cylinder bore
Diameter of rod
Diameter of pins
You are missing pin size, retracted length and stroke for the cylinders. Those other dimensions are not needed for sourcing cylinders.Good morning Dan
Here are the specs
Bf300 loader
17.9 inches reach (dumped)
45 cm
47.4 inches reach (ground)
120 cm
23° rollback
79.1 inches height (at pin)
200 cm
64.4 inches clearance (dumped)
163 cm
boom cyl: 1.77 inches
4 cm
boom rod: 1.18 inches
2 cm
bucket cyl: 1.77 inches
4 cm
bucket rod: 1.0 inches
2 cm
Based on dimensions I found in an older thread these should be a direct drop in replacement for the lift cylinders. The bore is larger (2" versus 1.77") so you will gain 28% more lifting power.Good morning Dan
Here are the specs
Bf300 loader
45 cm
120 cm
23° rollback
200 cm
163 cm
4 cm
2 cm
4 cm
2 cm
The boom cylinder od is 2.19Based on dimensions I found in an older thread these should be a direct drop in replacement for the lift cylinders. The bore is larger (2" versus 1.77") so you will gain 28% more lifting power.
2 bore x 18 stroke hydraulic cylinder, welded tang double acting cylinder | Magister Hydraulics
2" bore x 18" stroke tang hydraulic cylinder 3500 PSI double-acting. Heavy-duty hydraulics, 2-year warranty, free ground Continental US shipping. Magister tang cylinders manufactured using steel piston and steel threaded gland with wear rings for long life. Welded durable mounting ends, honed...www.magisterhyd.com
I suggest you double check all dimensions before buying.
Do you know the part number for the lift cylindersYou could reseal your cylinders and save all the adapting, or cobbling different cylinders.
Amazon.com: E-70726-68010 Boom Cylinder Seal Kit for Kubota Front Loader BF300, BF300-A, BF350, BF350-A, BF400, BF400G, BF400S+++ : Automotive
My hydrualic hose shop rebuilds cylinders for a third of what I could buy a replacement for. Have done a couple on various machines. I just take in hoses or cylinders and in 3-4 days time, I have new ones.
Might be worth checking out.
How do you arrive at 1.18 diameter piston? That is the rod diameter which would be tough to do on a double acting cylinder.Ok
The boom piston is 1.18
Thank you for that info
OK Dan,Based on dimensions I found in an older thread these should be a direct drop in replacement for the lift cylinders. The bore is larger (2" versus 1.77") so you will gain 28% more lifting power.
Are you confident of those numbers? I am not.OK Dan,
Rod is 1.18
Bore is 1.2
Retract is 29 inches
Pin is 1 inch
Pin to pin is 27 3/4
