Full Size -vs- Compact -vs- Sub Compact
gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
Jan 5, 2013
257
47
Sandpoint ID
www.gemstarcustoms.com
Where in your eyes does the cut come :confused:
Myself I think it is more about Tractor Size and Weight
It gets a little confusing in there with the BX, B, and smaller L series Tractors..
In my eyes if it is under 1500 lbs w/o Attachments it is a SC
Under 3000 lbs a Compact and Anything over 3000 lbs is a full size Tractor
How do you look at it????
bulldog_shotgun
B2150HST
Feb 3, 2013
59
SW, Ohio
I add a class, in my mind.
4500lbs+ or 70hp+ is full size
3000 to 4500lbs more than 40hp is compact
1500 to 3000lbs more than 25hp is sub-compact
1000 to 1500lbs more than 17hp is Ultra-compact
less than that is a garden tractor.
Kubota Newbie
Dec 28, 2010
533
81
Mount Vernon, Ohio
I do not think that the classification really matters all that much.
What matters is what do you intend to do with it. I see way too many people using these neat little four wheel drive tractors to do things or use implements that are meant to be used on a larger tractor. Just because Kubota, Case, JD and everyone else puts a cat one three point on these little machines doesn't mean that it's safe to hang a 1000 lb mower on the back of it (it's a marketing gimmic). It's gotten really confusing as the hp ratings have gone up on the little tractors. My M4500 is only about 49 pto HP, but it is more of a full size tractor. The old Farmall M I used to have was only 38 pto hp, but weighed more than twice as much as many small tractors now rated at that power. At the Farm Science Review last fall I was looking over Kubota's new stuff and decided that to get final drives and three point lift arms equal to what I have on the M4500 I'd have to buy a tractor rated at nearly 20 HP more.
So like I said, I think it's more important to look at the kind of work you'll expect the machine to do and shop for something with the weight to do it safely. A little bigger is probably always better unless space is an issue.
rednecklimo85
78 B6100E(brush hog, boxblade, snowplow) 85 B7200DT(loader and backhoe)
Oct 24, 2009
torrington,ct
Classifications change too. I believe my B6100 was/is considered a compact. But the bx series is considered a sub-compact and they are quite a bit higher HP, I'm unsure of weight tho. I know one thing, the BX series doesn't look like it would take the same kinda abuse my B6100 would, they look like an overgrown garden tractor to me. Probably just as tough, I just like the fact that the B6100 looks alot more like an old farm tractor.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,147
1,266
Near Lancaster, PA, USA
Much of the terminology in the world we live in has been influenced as much by the marketing departments as by the engineers/designers.
I don't worry too much about what to call my tractor choices except "too small", "just right" and "too big". Three names for ranges that cover it all.
hodge
Nov 19, 2010
2,905
453
Love, VA
The BX series is just as tough, and in many cases, weigh as much or more than a hp-comparable B series.
Between a BX and B series, you are going to get the same durability/quality, but the BX has less ground clearance.
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Well said!
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
It's not a hard system to follow. Kubota explains it pretty simple on the prior products listing. And no the BX models are nothing like a garden tractor. Ok they might be close dimension wise but the BX's are diesel engines with drive shafts and you can put a loader and backhoe on them. Garden tractors are gas engines usually belt drive to the rear axle with the exception of some Cub Cadet models. Garden tractors mainly cut grass and occasionally push snow with a small blade. That's about it!
http://www.kubota.com/priorproduct/BXSeries.aspx
KenB2920
L5240 brush hog,flail mower,wicked grapple,tiller,Danuser F-8 PHD,BB,RB 7' rake
Jun 17, 2011
145
Almont, mi
Well said!!! That is exactly how I feel.
Kubota makes nice garden tractors. I would definitely never consider a BX a garden tractor. $10,000 vs $1500 at home depot etc. There is a tad bit of a difference.
You definitely have to weigh out your tractor tasks and the size of each task.
Iowan
Kubota's
Apr 29, 2012
111
North central Iowa
I've had a cub IH 1650 and a Cub 1441 with snow blowers and tillers, Great garden tractor's for sure and nothing compared to to the junk they sell now!
The cub's weight was 800lbs the BX is 1400lbs, MMM deck 250lbs, loader 250lbs, cab 200-300lbs.
Here is a complete 460 Ford hanging off the loader on my BX, thats 700 plus lbs., close to the weight of my Cub's.
I have friend that uses a King kutter 60in tiller on his BX 2660, I think they are one rugged little over powered tractor!
