Kommander Z125S Won't Do Anything
Turkey81
Kubota Kommander Z125S
Mar 7, 2024
Mississippi
Hey guys, this is my first post here so if this is in the wrong spot I apologize. I have a 2016 Kubota Kommander Z125S Zero Turn mower that I bought new in 2016. I had to replace the ignition switch and the PTO switch at the same time this week and now I can't get it to do anything. It won't turn over or anything. I got the parts from the dealer so they are OEM parts. It's like one of the safety switches isn't working or something. I replaced the battery last week, but I still checked it to make sure, and sure enough the battery is hot. They changed the PTO switches on them and you have to get a pigtail with the new one to adapt it. The ignition switch also just simply plugged in. Both parts are simple plug and plays. Any idea what would cause me to have zero power. It doesn't click and the lights don't even come on. Is it possible that replacing the PTO switch did something to one of the safety switches? I checked all fuses also. I made sure the park brake was engaged, seat safety switch was pressed, and the handles were in neutral. Only thing I can imagine is either the ignition switch or PTO switch that I replaced is causing this. It was running fine when I decided to change those 2 parts. I changed them because the PTO knob was slipping back down and disengaging the blades while mowing and the ignition switch was so bad I had to uses a flat head screwdriver as a key. Any help is appreciated and thanks in advance.
Turkey81
Mar 7, 2024
Mississippi
I dont know if this service bulletin applies or will be of any help,
Thanks for the reply. My question is, wouldn't the lights still come on regardless of any issue with the starter. It's like its not getting any juice anywhere.
3,844
2,388
Have you checked the fusible link/fuse, it's probably near the starter?
hodge
Nov 19, 2010
2,960
531
Love, VA
Were the old sensors completely bad? Can you put one back in, and see what happens? Narrow down which one is the issue?
Turkey81
Mar 7, 2024
Mississippi
[/QUOT
Thanks for the reply. I checked those but I think you are on to something because when I went to moving stuff around all the sudden the lights came on and I heard a click. I narrowed it down I "think" to the slow blow fuse or box fuse whatever you call it under the seat on top of the gas tank. I can wiggle it and it gets power. Little confused because a fuse is either blown or its not there shouldn't be an in between, but I checked all the wires and none are broken or skinned.
Turkey81
Mar 7, 2024
Mississippi
Hey, thanks for the reply. As I said above to PoTreeBoy, I think I was able to narrow it down to the slow blow fuse under the seat. When I get home from work today I'm going to replace it with a new one and see what happens. I'll post the outcome just in case someone else in the future has this issue this may help them.
hodge
Nov 19, 2010
2,960
531
Love, VA
Great! It's pretty common for a person to start a thread, and not follow through with the end results. There is bound to be someone who can benefit from your experience.
Welcome to the forum, by the way!
5,515
2,226
the slow-blow fuse is commonly "failed" when a hot wire is shorted to ground, OR if the battery is mistakenly hooked up backwards. The latter is fairly common when replacing the battery, just the way the battery sits in the chassis it's not hard to install it backwards. Also parts store batteries are often reversed in how the + and - terminals are put on the battery-and with that said, you have to be VERY careful how the battery is installed on these mowers since when you drop the seat back down, if it's incorrect, the seat base can hit the terminals causing a big short circuit. That short can result in fire, and since the battery sits right next to the plastic fuel tank, which right under your butt, you DON'T want that!
daddycreswell
Kubota Z125s
Apr 10, 2025
Middle Tennessee
Hello Sir, I come to you for help. It would seems I am having the same issue, every time I turn the key it blows the 30a slow-blow fuse. So I pulled the pigtail off and started jumping it from the pigtail and it keeps blowing the fuse. I can't find a wiring diagram to help me figure this out. So where would you look for the this hot wire short, and is there a way to find it? I have bought a 12v light bulb to use so I stop blowing 7 dollar fuses.
3,665
2,087
Here are the two main diagrams. I had to guess, as you did not give your serial number or which engine you have.
