I have a 1998 kubota L35 that is no crank no start. When I hook up the battery I get lights on the dash but when I turn the key absolutely nothing happens. The only thing that happened that could have caused any issues was my dad said that he left the lights on after using it to plow the driveway.
What I have done:
-Replaced the slow blow fuse
-Tested the battery
-Cleaned the negative terminal ground
-Checked all other fuses
-Bench tested the starter
No fuses were blown, the battery tested weak but held a charge, and the started worked. Prior to testing any of these things, I could get it to fire up here and there and even when I got it running, I would run it for almost 2 hours to let the battery charge up and the second I turned the tractor off it would be no crank no start again. Now it hasn't started in almost 2 months so I am stumped on what to do next. This tractor worked perfectly fine for 15+ years with no issues other than a couple of blown hydraulic lines.
Any guidance would be greatly appreciated.
What I have done:
-Tested the battery
