L245, no reverse, 1st, or 2nd gear
mudjunkie
L245
Mar 5, 2024
Oregon
Looking at potentially buying a used L245, seller says it lost reverse, 1st and 2nd gear, no funny noises, shifts into the appropriate spots, just nothing happens when you let the clutch out... anyone else experienced this??
6,334
There is quite a few things that could cause it to be doing that.
Most likely would be shift fork or gear damage.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
642
255
Herald Calif.
As Wolfman said shift fork. Reverse gear has its own shift fork. First and second gear would be a separate shift fork. It would be odd that both of them are broke. My guess is something in the actual shift cover causing the problem. This is a 45 year old tractor and can have a lot of wear and things. Relatively easy tractor to work on. I would remove the cover with the shift levers in it and inspect it. You should be able to see your problem then.
3,316
, hoping it's the shift forks, 🙏 it's reasonably cheap, and in 9/10 condition cosmetically!
It’s funny how we will diminish risks… based upon perceived desirability.
(I should have remembered that when I thought I wanted to marry that previous wife.)
Suggest to the seller that you’ll buy it at the agreed price…..And You’ll pay the cost of repair…. if HE will have it fixed before the sale.
(In such a case if it turns out the repair is wildly expensive ….it won’ t be your problem.)
Be prepared for that offer to be refused …. He may know more than he’s letting-on.
mudjunkie
L245
Mar 5, 2024
Oregon
I'm a diesel mechanic among other things, I'd rather handle the repair myself, from what I can tell it shouldn't be too much money for parts since the whole trans isn't shot... still hoping it's just shift forks...lol
6,334
I get basket case tractors all the time, I've yet to get one running properly.
