a little hydraulics help for a n00b...
Showmedata
LX3310
May 18, 2022
202
169
Boulder CO
I'm building an implement that will use my Kubota 3rd-function. These are the 3rd-function ends:
I cannot decipher the markings on them to correlate with connectors to buy.
Is this the correct set to match them?
Thanks in advance.
2,012
Dustball
2016 B2650HSDC
Sep 15, 2023
409
265
Hudson, WI
6,565
Using Teflon tape on hydraulic fittings is not recommended. The tape can possibly get into the system and then cause problems. Here is a recommended product to replace the tape. You can find it on Amazon for about $7.
5,154
Yet teflon tape is standard practice in every Kubota service department and used by dealership technicians during new tractor assembly.....
I rhink the dangers of tape are way overstated but the anerobic liquid sealants are without a doubt way more convenient and easier to use.
Dustball
2016 B2650HSDC
Sep 15, 2023
409
265
Hudson, WI
Teflon tape is to be used on tapered threads, not straight threads or on flared fittings.
When you do use teflon tape, don't apply it to the first thread. Start the tape 1 thread back from the end to minimize the risk of thin strands of tape breaking off and getting into the hydraulic system.
My preference is Loctite 545.
6,565
Perhaps. I have a friend who is a Cat tech. and he says if you are caught using tape you're gone!
Showmedata
LX3310
May 18, 2022
202
169
Boulder CO
sealant: since I have some Nylog Blue on hand from a heat pump installation, the teflon tape can stay in it's drawer this time. I appreciate all the advice.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
104
Lopez Island, WA
RectorSeal #5 is what I've used for tapered pipe threads since I worked in Ag Engineering at UC Davis back in the early 80s. Works well, works on steam stuff too.
