Anyone ever have a trailer with metal grating for a deck?
3,667
As long as it's painted with real paint NOT 'powder coat', it'll outlive every one here. …..
Can you elaborate on that ?
(I have a “powder coated” dump trailer stored out in the weather for 6 years now and it’s holding up just Fine…. even the “bed” / interior….which has hauled rock and gravel which is very abrasive….is holding up well….. the only issue is the decals are curling up and fading.
5,806
Every item I've seen that gets a nick, cut,slice of the powder coat allows for moisture to touch the raw steel. steel rusts, expands, 'bubbles' the powder coat, allows more moisture in..repeats until huge strips of PC come off.It's not easy or fun to TRY to repair ,usually have to remove 3 or 4 x the affected area.
The salty winter roads here only quicken the self destruction.
I've seen 4 year old trailers in the scrap yard due to this.
It'd be interesting to know who powder coated your trailer and what products were used.
3,667
It’s a “Load Trail” model DT14 https://loadtrail.com/
Advertising video of their ops… includes a little of the finishing process::
5,179
I absolutely agree!
Powder coated steel items in the North are an absolute disaster.
Prolly just fine, even when stored outside, in Texas though!
5,806
those LT trailers also get a PRIMER, something not usually found on most trailers, at least not up here in the 'salt belt of Ontario'
Only salt used in Texas is probably blue lick cubes for cattle ?
jyoutz
Jan 14, 2019
3,441
2,529
Edgewood, New Mexico
That metal grating will be the PERFECT place for rust to grow.
Might be a great trailer for Arizona, or New Mexico, but for NJ. ??
Using it ONLY in Summer, should be OK in NJ though.
Northern AZ and NM use road de-icers in the winter.
3,667
We common Texican-citizens take our gov’s public comments with a “grain of salt”… 🤪
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,636
2,089
Western MT
Wood is generally easier to replace, but anything can be slippery covered with the right type of mud.
Depending on your skills with metal, wood decking might be a better choice. However, if you tow in Winter, anything is going to corrode and if the decking doesn't the frame will.
Always a tradeoff.
UpNorthMI
May 12, 2020
849
566
Up North, MI
This has 7k axles and 215/75r17.5 16 ply tires. I will be towing the same excavator as you - what size tire did you blow and what did you upgrade too? I do not want to blow a tire while towing stuff......
Of the top of my head - My trailer has 8k axles and was fitted with 235/80R16 tires, they were load rated E my goal is to upgrade to a load rating of H which is about 4,000 lbs per tire. Nearly all of these tires are out of China.
5,157
A friend purchased new tires for his trailer and said that Good Year tires are still made in the US. Don't know about all of them, but his trailer tires were. They weren't inexpensive, but it was what he wanted. Good US-made tires.
5,157
Does NE use thousands of tons of road salt each Winter?
Nope, not thousands, but more likely millions or even billions of tons. They also have a brine that is mixed in large plastic vessels that appear to hold at least 10,000 gallons and is dispensed into trucks that spay it onto the roadway before the storm to keep the snow from sticking to the surface. The problem is that the product sticks to the metal of your car or truck and promotes rusting. Some chemicals can be sprayed on the truck to break the bond so it can be power washed to remove it, however, you have to make sure to get every nook and cranny, which is almost impossible.
5,179
The OP has his location listed as,..... Malcolm, NE (Nebraska).
I seriously doubt that Nebraska uses road salt in those high tonnage amounts.
5,179
Dustball
2016 B2650HSDC
Sep 15, 2023
441
302
Hudson, WI
Not sure about Nebraska as a whole, but just the city of Lincoln used 469 tons average over the last 3 years.
Where I live.
TCMA = Twin Cities Metro Area in Minnesota.
This table is for state, county, and city salt contract for use on the roads in the TCMA. Actual usage range from 89% to 103% of the contract amounts.
As for Minnesota as a whole, a recent article says-
Overall, the MPCA estimates Minnesotans apply about 445,000 tons of salt to paved surfaces every single year.
5,806
gee you'ld think the 'greenies' would be screaming about the amount of salt being used.....
I Know 'they' FINALLY figured out why a couple lakes died up here. seems if you keep dumping enought truckloads of salty snow into them,oopsy,.. the lake 'dies'.
forceten
BX 25d, Grand L6060, Kx040, GL7500, ZD1211 With cab
Sep 4, 2015
281
26
New Jersey
ummmm I had to go look at my profile Does state NJ
Not sure if I said NE anywhere and if I did I meant north east. NJ hasn't had any real snow now in 2 years but we can and do get snow. I won't be using the trailer in winter only spring and summer
forceten
Sep 4, 2015
281
26
New Jersey
Well that doesn't instill confidence..... the 16 ply tires are load range H on that trailer. but you had a 10 ply load range e? Load range H seems right to haul a 10k pound excavator.
5,179
Sorry.....
My response was intended as a response to poster in response #11 who is from Malcom, NE.
