Having investigated many industrial accidental death scenes involving failed equipment, both hydraulic and mechanical caused by both humans and equipment failures, I worry about servicing my Kubota MX5100 tractor with the Front End Loader installed. To service the air cleaner, battery, checking oil and cleaning the radiator screen as well as accessing a couple of the zerk fittings, requires raising the FEL and working underneath it. So as not to have to chain the FEL up every time, I choose to use hydraulic cylinder lockout devices.  So I made my own out of heavy walled aluminum pipe. The aluminum prevents scratching the chrome rams. I made two sets, one for each cylinder.  I cut the pipes to length then split them lengthwise forming two matching (2) halves.  I then place them on the cylinder rams and use pipe/muffler U-Clamps to assemble the two (2) halves back together.  I have marked them and painted each set a different color to insure they are assembled correctly. They work great and are very stable.  I have included some photos of them unassembled and assembled in place.
