M9000 radio
im4Kubota
M9000
Feb 26, 2024
Northern MN
Hi there, first post here, I tried searching first, sorry if it's repetitive I didn't find what I'm looking for.
I own an 05 M9000, cab model, and trying to swap out the factory radio. It's giving me fits and doesn't want to come out. No bolts around the face (trim is popped off) and I tried depressing clips on side, but I'm not getting any movement.
Has anyone dealt with the m9000 factory radio? Am I missing something, hopefully easy?
Thank you
Dustball
2016 B2650HSDC
Sep 15, 2023
513
380
Hudson, WI
It'd probably be easiest to pull the roof off to gain access to the radio cage and release the radio that way.
Can you find the radio you have on eBay? Pictures on eBay may help you "look behind the curtain" on how the radio comes out. Is it this one you have? https://www.ebay.com/itm/173499380693
im4Kubota
M9000
Feb 26, 2024
Northern MN
I found the answer somewhere else. You have to remove the top, it is bolted in from the top with 2 bolts. Thanks for the suggestions.
