So over the last few weeks the oil pressure light started to stay on for a second or two after starting and I didn't think anything of it.
Last week I bogged her down and then the light started to flicker at idle. Now she sometimes flickers at idle and minimal idle increases, sometimes she doesn't. I changed the filter and oil (10w 30 standard) thought it was fixed but it came back today (for a little while) I'm thinking (hoping) its the sending unit. I do see other things mentioned on this site like the check valve, pickup tube and O-ring (most likely to me would be the check valve. I guess I'll start with a mechanical gauge as a check and pray its just a failing pressure gauge, unless someone has other suggestions...
