BonnySlope
BX2380FEL, Add-A-Grapple, Titan 48" Box scraper, 60" Rake, 72" Rear Blade, Flail
Came across a Howard Ratavator (tiller) and I couldn't pass up. It's a HR 10 series and yes a little on the large size 60", no PTO shaft. (under 175 w/clutch) My research came up with 25HP min. hitting the scale at 627 lbs. Tine shaft rotates free. Looks like the chain cover been replaced. I'll take a look tomorrow. There a flange thats on the splines looks like it may have been part of some type of clutch pack, going by the loose flange behind it and there was a bolted clamp on splines, that I removed. Still not moving with puller and lot of blaster, letting it sit over night. Then dust off the heavy weight pull or try a little heat first with impact.
I thought it would be a get project for 3.
I had luck on my side.
