Uplifter valve sticking?
Will open it up next week and see whats in thereUplifter valve sticking?
How and where did you measure pump pressure and what was the number?3 point linkage wont go up under load Filter is clean Good pressure from pump.Orings replaced in lift cylinder..What to do next? At the moment the 3 point will slowly rise with high revs without load
We Took off the banjo fitting under the seat didnt measure the pressure but came out pretty strongHow and where did you measure pump pressure and what was the number?
thanksBefore taking things apart try sending a private message to " rbargeron."
He owns and has owned a number of older L's plus is very well educated technically.
It may be an issue with the feedback rod but ask Dick
You need a pump discharge pressure test at that banjo or the pump outlet. That test hookup is a bit tricky to make.We Took off the banjo fitting under the seat didnt measure the pressure but came out pretty strong
All fixed Crap in relief valveYou need a pump discharge pressure test at that banjo or the pump outlet. That test hookup is a bit tricky to make.
Or we could just keep guessing.....
