I have a D1105 in a light power plant the engine was having issues starting, I determined the injectors were the issue. I bought new injectors from kubota and installed them. When i was replacing the injectors, I saw the fittings on top of the Injection pump turned. I took this as them being loose. I tightened them down. After I did that, I had zero fuel coming from the injection pump. I later found out that those fittings determine flow rate and there is a procedure for doing that. How ever I cannot find anywhere the procedure on how to do that, can anyone help me.
