I am taking delivery of a slightly used L3901. It has the bh77 mounted and that’s it.
I have a grapple I’d like to use and also I would like to have rear remotes for top-n-tilt and maybe use one for a backhoe thumb/post hole drill.
I have read through many online posts but none with exactly my situation.
For the front I believe the Summit valve is a good (although $$) solution. It looks like it would install between the loader valve PB and the backhoe feed. I think I really only need an electric valve and a switch. The question I have is the electric valve in the kit has a T port out. Is there something to turn that into a PB like on the P40 valve?
Then on the back I believe I would take the feed from the 3rd function and route that to the rear remote valve. From there the PB out would feed the backhoe and the return from that would remain the same.
Does all of this sound logical and correct? Any suggestions for an 3rd function valve? Any suggestions on mounting the rear remote valve? I’d like to have it under the seat but the levers would be miserable to articulate.
Thank you! Love this page for the knowledge I gained in selecting my L.
