I have a B3200 and would like to purchase a set of wheel spacers. I cannot find the lug nut pattern nor the bolt size of the lugs. Any assistance would be most appreciated.
Do they only hit when you turn sharply.Thank you for the replies. I was asking because the winter chains hit the frame even after flipping the tires inside out (and yes opposite sides). I guess I will just deal with it.
Yes, I will look into that. I want to say that the tires would hit the frame even with out the chains, so I turned the tires inside out and rotated them and it improved slightly. I will check the stops. Thank you.Do they only hit when you turn sharply.
If so you need to adjust the stops.
