Block Heater L2350 question
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
Perhaps it is self evident....I don't know.
I have ordered a Block Heater for my Kubota L2350DT. I can start it in cold weather (sub 30°F temps) but it takes a few minutes of running the glow plugs and cranking the engine. Engine will fire, quickly die, repeat....until it finally warms up.
So....hoping a block heater will make things better.
Question:
After removing the 'knock out' style freeze plug, does the new adapter drive in all the way to the 'step' on it. Appears that it would.....but also looks unnecessarily long. The instructions do not say.
Also no mention of a sealant on the adapter itself (where it seals against the block). Only for the bushing.
What say you guys? Thanks.
3,557
1,993
The lip may or may not contact the block, the bushing may contact the inner wall first.
Remove the soft plug, clean the bore, and dry it. Use lock-tite on the insert and tap it into the bore. It will drive in fairly easily, you will see if the lip contacts the outside edge or it will stop if it contacts the inside wall. You can hear when it contacts.
I screw a pipe plug into the sleeve to drive it in and to paint it.
Put some sealer on the heater and screw it in, refill the cooling system, and plug in the heater to test it.
10,734
All of mine don't bottom out.
They are about 1/2 way up the taper if that.
I use a block of hardwood to drive mine in.
4,063
A hair dryer directed at the air filter/intake while cranking will make most of these diesels believe it is summertime.
6,251
My forklift had one big glowplug IN the intake, needed 2nd battery for that !
If you need a block heater ,consider also installing a battery warming blanket. batteries lose a LOT of power when cold, take longer,harder to recharge. Nice warm battery spins the engine faster,starts quicker.
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
Hopefully I will be able to see or measure the depth of the cylinder wall after removing the freeze plug and the coolant level is low enough.
I don't want to hit the cylinder wall and the instructions DO warn against that situation.
Thanks all for the replies.
Probably should have done this years ago....but I don't use my tractor very much during the winter (what we have of a winter here).
But in recent years....we have been experiencing a certain number of days into the 'teens' and low 20's (cold for here).
Whatever happened to 'Global Warming'?
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
So.....the block heater finally arrived.
The Depth of the stepped portion is only 5/8", so hopefully there will be no issues with hitting a cylinder wall before fully seating. I will measure first.
Some sealant for the new adaptor bushing.
10,734
Most of my adapters only seat about 1/4 to 1/2 way.
I haven't bottomed one out in the hole or hit a cylinder wall.
And ya you don't want to bash a cylinder wall they are not that thick.
Just dry fit it, I bet you'll find that very little of the sleeve goes into the block.
FYI: Drain the coolant, it's the only easy way to do these.
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
Question:
Does 20 thousandths of 'Taper' sound like a lot for something that is going to be an interference fit?
I was going to install the Block Heater today but thought I'd better check the diameter of it to be sure it was correct. I discovered that over the length of the 'step'....it is tapered somewhat.
Maybe I'm overthinking it....but I'm not sure I like the idea of a tapered plug going onto a diesel engine (with its attendant vibrations).
2,947
The hole is also tapered from what I remember about the “freeze plugs”.
10,734
How do I put this nicely...
Yes your overthinking the heck out of this.
I've installed a ton of these never worried about the taper or anything else and have yet to have one leak, let alone fall out.
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
Good enough, then I'll do it. (y)
If true....then that would make more sense to me. A freeze plug would seem more malleable than this bushing looks.
Just something about forcing a tapered plug into a non tapered hole (made of cast iron) that spooks me a bit. A cracked block at a core plug hole would be fun to try to fix.
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
Time to change my radiator coolant, so also a good time to finally install this thing. All went smoothly. Expansion plug was not difficult to remove, despite being in a spot not too easily reached.
The bore on my engine actually had a small lip on the righthand side...that would prevent the adapter from going in too deeply, if ever that was a concern.
A little sealant on the block adapter prior to seating it.
I made a 'witness' mark on the block and adapter, just to be sure the adapter was not turning in the bore as I tightened the heater element.
A little dielectric grease on the cord fitting.
And DONE!
10,734
And DONE!
May it serve you well this winter!
