Kubota 4310, everything in neutral, all lights on dash come on, Battery fully charged, glow plug light come on for few seconds then goes off(like it should) turn key on to start and Nothing not even a noise? All help appreciated
It’s manual shuttle shift, I will check negative connection.Most likely a safety switch. HST or manual? If HST, while holding the key to the ON position, slowly rock the pedal back and forth, Wiggle your weight around in the seat... or adjust the PTO knob a bit. If that doesn't work, start checking wires to the safety switches for chewed wires...
Also, check the ground wire from the battery, to see if it's clean, not corroded and tight.
Ok will try, possibly not tomorrow we may get wintry conditions here in Louisiana.Got a voltmet? See if your’e getting power to the small wire on the starter solenoid When key is in start. If not start backtracking. If you do get power then maybe the solenoid. You can jump it straight to the batt wire on the starter.
Discovered that Neutral Safety Switch was not working. Part # TA040-43900 Switch Lever.Kubota 4310, everything in neutral, all lights on dash come on, Battery fully charged, glow plug light come on for few seconds then goes off(like it should) turn key on to start and Nothing not even a noise? All help appreciated
Neutral Safety Switch on Shuttle Shift not workingDiscovered that Neutral Safety Switch was not working. Part # TA040-43900 Switch Lever.
Last for this post I hope, Thanks for all the Help…Discovered that Neutral Safety Switch was not working. Part # TA040-43900 Switch Lever.
Thanks for letting us knowLast for this post I hope, Thanks for all the Help…
