I Have a BX23s with the skid steer mtd Digga auger motor which turns real slow because of the anemic pressure and flow rate of the 23. I would like to mount a pto based hydraulic pump to provide a higher flow rate and pressure. However, I can't tell what [flow rate and pressure] pump I should get. The digga specs state [max pressure 3500psi@16gpm and max flow 30 gpm@1800 psi]. The pump I think would work is 2500psi and 16.6 gpm at 540 pto speed. So how would I figure out if the 23s at 540 pto speed could exceed either of these max specs? Also if the pto speed is 540 at 2500 rpm on the tractor if I run the 23s at lower speeds will the PTO speed run at lower speeds and thus drive the pump output at lower psi and gpm? Final question how can I stop the auger mtr other than by disengaging the rear PTO and thus the pump output.
